Hey there everyone.
I am relatively new to the hobby. I picked up a RBION. It looks like the magnetic bolt height was never properly adjusted. I believe it should be sitting flush. Anyways as a result, it has mushroomed. I'd like to remove the bolt, coming out the play field side and grind it down. However underneath it is held by a nut. I'm assuming you simply turn the nut counter clock wise but it will not break loose. I mean I can get it off, but I'm afraid I may break something or crack the play field. Any suggestions would be greatly appreciated.
Thanks in advance.
Pic 1 - http://oi59.tinypic.com/351bb5h.jpg
Pic 2 - http://oi58.tinypic.com/qmz4v6.jpg
