Hello, I am having some trouble removing a playfield post for Cliffy installation on the RBION scoop. I had a Cliffy on the game already when I purchased it but it has become a bit raised in the middle causing some airballs so I wanted to replace it with a new one. I ran into some problems removing the playfield posts securing the Cliffy to the scoop hole.
The post on the left side was attached with a nut on the bottom of the playfield and I removed it without issue using a nut driver and then pulling the post from the top of the playfield. On the right side of the post there was a flat-head screw under the table I removed. Now I still have the post attached on the top of the playfield that I can't seem to remove. I have tried slipping a small wrench over the top of the post and it spins around but does not actually come off at all.
I'm not sure how to remove this post now. What am I missing? I took picture of the top and bottom of the scoop assembly. IMG_5997 (resized).JPGIMG_6001 (resized).JPGIMG_6003 (resized).JPG
