(Topic ID: 196792)
Raven - no sound, checked logic w/ DMM
By Topher5000
2 years ago
  • 37 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by Topher5000
#1 2 years ago
So, I haven't had sound in a while on my GTB Raven https://pinside.com/pinball/forum/topic/raven-no-sound
It used to come on every once in a while, but it played the wrong sounds or sounds that didn't belong in the game. Haven't heard anything in a while.
In a topic about logic probes, cody_chunn & wayout440 mentioned using a DMM to measure logic states, so I tried it last night.
First, I unplugged A6P1, turned it on, started a game & measured the pins on the connector. I got P1=3.46; P2=3.49, P3=0; P5=3.8; P8=0.67 & P9=3.95. However, measuring P18, the audio out, I got 0.
I also checked the 5v power supply & it was fine. On the aux. power supply, I measured between P2 & P3 & got 0, gnd to P4 = -0.13 & P6-P7 3.2. I don't think that it's the problem anyways, since the reset & test buttons on the sound board produce bongs.
I also randomly test caps on the SB. C6 = 0/11.46; C9 = -12.25/-0; C8 = 12.73/0; C10 = 12.73/0.01; C18 = 5.12/0.01; C19 = 0.01/-12.25; C20 = 2.15/0.15 & C27 = 2.15/1.6.
The problem is I have no idea how to interpret these readings or where to go from here. To me, the no audio out signal from the SB means the problem's on it. Any thoughts?
#2 2 years ago
Crap. Read about checking caps & they have to be removed from the circuit. That's beyond my skill & there's a boatload of them.
What I did was stick the black probe in the ground pin of the connector & touch each side of the cap.
Anybody have an idea of what I should do next? There's an electronic supply/repair place in town, but they don't diagnose.
#3 2 years ago
I printed out the spec sheets for Z12 & Z13 on the driver board. Pin 8 being the only one that's low bugs me, but maybe it's supposed to be that way. I'll try to check the logic states tonight.
#4 2 years ago
I'm going through the same thing do you have a light working on your sound board
#5 2 years ago
Yep, the light blinks & both button produce beeps, but there's no sound.
#6 2 years ago
Hope someone can offer a few things to check out !!!
Quoted from Topher5000:
#7 2 years ago
Allllllrighty then.
I finally checked the logic on Z13 on the driver board (you get used to playing with no sound).
Leg =0.16; Leg 2=2.34; L3=0.16; L4=0.49; L5=0.12; L6=5.08; L8=5.08; L9=0.16; L10=3.97; L11=0; L12=3.99; L13=0 & the Vcc=4.99.
Legs 3 & 4 both being low, it looks like I need to have Z13 replaced, correct? Would this cause no sound at all or just the loss of one sound?
Any Gottlieb experts know if the rest look okay or if I should check other chips? kenlayton ? chrishibler ?
#8 2 years ago
Afternoon bump
#9 2 years ago
Diode check the chip with power off.
DMM set to diode check.
Red on lower left leg.
Black on all others should read .4 to .7.
Short to ground? Check schematics tonsee if it's really connected to ground.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
#10 2 years ago
Thanks Chris, I'll check it tonight.
Here's a crop of the Z13 schematics.
#11 2 years ago
I checked Z13 as you suggested & this is what I got.
L1=-045; L2=-319; L4=-247; L5=365; L6=-349; L8=-348; L9=-045; L10=-344; L12=-344
You can understand my confusion. I have no idea what these numbers mean. Mind you, I have a cheap DMM.
#12 2 years ago
You might need a better meter. I can't make sense of those numbers either.
What model meter are you using?
http://www.ChrisHiblerPinball.com/Contact
#13 2 years ago
It's a Canadian Tire meter. Can't find it on the website, but my neighbour just bought one, so I'll get the model number tomorrow & try to find it. I think I paid about $30 CAD for it on sale, regular $50.
I'll see if anybody I know has a better one.
Side note: it has a signal insertion function. What's the purpose of that?
Thanks for your help!
Edit: I tried using the diode mode on the MPU chips, couldn't understand the readings & ended up shot-gunning it. I've read a lot the last year and a half & really want to diagnose this properly. It would be sooooo satisfying.
Edit #2: Should I be measuring with the power off? I measured with it on.
#14 2 years ago
Gack! Yes. Power off. Give it another try.
#15 2 years ago
I'll try again tonight.
Thanks.
#16 2 years ago
Chris, I checked it with the power off & this is what I got:
L1=600; L2=031; L3=599; L4=016; L5=599; L6=423; L8=424; L9=599; L10=582; L12=589
I'm assuming my DMM doesn't display the decimal point & 016 is 0.16
So, is the chip bad since L2 & L4 are so low?
Edit: Just saw that you had said power off. Duh.
#17 2 years ago
Sorry. One more thing to do.
Did you remove the board to conduct this test?
If you don't want to remove the board, you can remove J1 and J5 from the board during measurement. This ensures you aren't reading a "sneak circuit".
If the reading for pin 2 and 4 remains the same, then the chip is most likely bad.
#18 2 years ago
No, the board wasn't removed. I'll pull it & test it tomorrow. Thanks.
#19 2 years ago
I checked with those connectors unplugged & this is what I got.
L1=717; L2=578; L3=716; L4=015; L5=572; L6=574; L8=578; L9=711; L10=577; L12=586
So, I guess the chip's bad? There's a local place, NuTech, that does good board work, except they don't diagnose. I'll call them & have the chip socketed & replaced.
Interestingly, the sound came back on Friday. It started playing random sounds that didn't belong in the game & then started constantly playing the game play music. Haven't heard it in months. It stopped when I turned it off & on though. It had been resetting due to the power connector on the MPU & I had moved the wires around. I think it was coincidence though.
#20 2 years ago
I completed the ground mods, tnt has on YouTube from Todd tuckey and mine started working. It's listed as gottlieb system 80 ground mods
#21 2 years ago
Yeah, I've done the ground mods, replaced the 5v pot, the transformer rectifiers & re-pinned a lot of the single sided connectors with no luck.
#22 2 years ago
Just out of curiosity, did you run a new ground from the sound board? I had a monte carlo doing the same thing. I ran a separate ground right to the sound board and that fixed it right up. These boards are really finicky.
https://www.flippers.com/gottlieb_ground_cures.html
#23 2 years ago
I'm pretty sure I did but it was a while ago. I'll check tonight.
#24 2 years ago
MAKE SURE YOU HAVE RUN THE GROUND WIRE on the interconnect between logic and driver...its missing on Raven and all system 80, 80A, and most system 80B games...it is on far right side opposite the single ground. It fixes a ton of other issues.
#25 2 years ago
Do you meant the 40-pin connector between the MPU & driver board?
#26 2 years ago
He means to add an extra ground between the MPU and driver board. It you've done the ground mods then this addition is redundant and unnecessary.
Drop me a PM. I'll diode check a board here. My guess is that you've found the bad chip. There is no reason for Z13/4 to read that low.
#27 2 years ago
If you do my Ground Mod fix in this video, you will solve TONS of other potential problems--shutting off, coil not working intermittently, sound cut off, etc, etc, etc....after doing this mod over 500 times in the last 30 years, we rarely have issues with those machines! AND...running the single new ground wire in connector between A1 and A3 again....Todd from TNT
#28 2 years ago
Thanks Todd, I'll check it out!
#29 2 years ago
Well, I had Z13 socketed & replaced. Still no sound. I'll check the driver board & then concentrate on the sound board. Unfortunately, I don't have access to an eeprom reader.
Plus, now the lower right sniper doesn't pop up. Too big a coincidence to be a coincidence. I'll figure out which solenoid it is & track it down. One has a jumper wire on the driver board instead of a diode so maybe that got dislodged. I'll start another thread for that if necessary.
Edit: On a good note, they had left the chip for me to install so instead of pushing the legs against the table, I used the inside jaws of my digital vernier to measure the width of the holes in the socket, zeroed it, then put the chip in the outside jaws & used the roller to squeeze the legs until it read zero. Worked like a charm.
#30 2 years ago
From Atomicboy's tests (linked below): First, with the game in attract mode, you need to short pins on the sound board. You want to short to ground the Sound 1, 2, 4, 8 (and possibly 16 and 32, depending on the game). If you get a different sound as each of these through the speakers, your sound card is fine. If you do not, you have a sound board issue (unlikely you have a bad sound card).
These are pins 1, 2, 3, 4, 5 and 8. If this doesn't produce sounds you can stop chasing driver and MPU issues until you get the sound board working.
https://www.maaca.org/viewtopic.php?f=22&t=2044&sid=329add4230f5b2dca2d7c8156c178436
#31 2 years ago
Dothedoo, I did that a while back in answer to you were in my other thread. I grounded pins 1, 2, 3, 5, & 8 and got no sounds. I'll do that again tonight though.
#32 2 years ago
Ok, then you'll need to focus on the sound board, and maybe its connector. The fact that the LED blinks and you get test tones is a good sign. I can't remember my results from grounding the input lines on my Raven, but I know not all of them produced sounds when grounded.
1 month later
#33 2 years ago
I had an ah-ha moment.
I was reading about grounding pins to try to get sounds to happen & then grounding pins on Z13 on the driver board after testing the SB, but didn't understand the first part. Then I read someone's thread somewhere about A3 on the sound board, so I looked at the schematics & A3 is the chip just before the SB output & I figured out that that's where I should be grounding the pins to test the SB.
I grounded pins 4, 14, 8, 13, 17, 18 & 3 on A3 & got nothing. I also grounded pins 1 thru 8 (that were used) in the A6P1 connector & got nothing. Pin 9, the reset, produced the bing sound.
I checked voltages before pulling the SB, but forgot how to check the chips with my DMM, plus football came on. I'm at work so I'll read up on checking the ICs & study the schematics to try to work back from A3 to see what other ICs to check.
Thanks for the help & the patience.
#34 2 years ago
I checked A3 with my DMM & leg 4 measured low, my meter read 058, so I checked B3 & got the same thing. I then checked E3 as a comparison & leg 1 was low, so I checked A2 & leg 1 was also low.
I rechecked them a couple times & got the same results, so I don't think I'm doing it wrong. When I first had sound problems I re-pinned A6P1, but in my newbness, I did it backwards & didn't realize it before I turned it on, so I may have fried the SB. At this point I'm thinking I should just get another SB. What do you guys think?
#35 2 years ago
Sounds like you've localized it to your sound board, so that's what I would do.
#36 2 years ago
Rats.
I'll ask around & see if there's any one around here with one to sell. A tech came over a year or so ago & he said he thought he had one, but he'd had a break-in & wasn't sure. I'll give him a call first.
#37 2 years ago
Fellow pinsider erak brought his friend's SB over on Saturday & it's definitely my SB. Bought the board & now it's working!
I guess what happened was I re-pinned the connector backwards, sent 12v somewhere & fried the board. I thought it was working as every now & then the gameplay music would play. I then proceeded to chase my tail.
Learned a lot along the way & would do it differently now.
Thanks for everybody's help!
€ 8.40
Gweem's Mods
Cabinet Parts
Vandelay Industries
$ 299.00
Displays
Boston Pinball Company
$ 119.95
Singer Pinball Designs
$ 90.00
Lighting - Under Cabinet
$ 40.00
Pinfarmer Mods
$ 239.00
Tilttopper
Third Coast Pinball
$ 79.95
$ 29.95
$ 209.99
