Fired up the game Thursday & there was no sound but after reseating the sound board connector, the sound came back. Last night, I couldn't get the sound working. I imagine I'll have to repin the connector or at least reflow the solder. Is there something else I should check first? If I need to repin, what connectors should I get?
Also, how does the SB function? There are two square buttons. One gives a high pitched beep & the other gives a lower pitched beep. The LED blinks reasonably slow. Is this normal or should it be steady?
