New! Dark mode!
(Topic ID: 241287)
Raspberry pi arcade
By Daditude
1 year ago
  • 84 posts
  • 20 Pinsiders participating
  • Latest reply 1 year ago by fissionch1ps
  • Topic is favorited by 25 Pinsiders
There have been 12 images uploaded to this topic. (View topic image gallery).
There are 84 posts in this topic. You are on page 1 of 2.
#1 1 year ago
I am a newb when it comes to raspberry pi, and I need help. Here's what im looking for:
I already have a fully working arcade machine with a led screen. I would like to install a raspberry pi in it to save space in my game room. I like arcade games and nintendo games mostly, but the more games the merrier. I need something that can play a lot of games, works with my led screen, and can hopefully use my current joystick and buttons.
What do i need to buy, and where can I get it?
#2 1 year ago
I'm using a Raspberry Pi 3B+ in my bartop arcade.
You can download emulators/roms for free.
Buy a big enough micro sd, at least 32gb class 10.
Check these sites:
https://www.sossolutions.nl/raspberry-pi-3b-plus-starterkit?gclid=CjwKCAjwzPXlBRAjEiwAj_XTEVR5kAk812CH-MtiqaM70WovUEovyiRCs8ogVzEqOyY7RHyIJ7_clhoCPqcQAvD_BwEb(it's Dutch)
https://www.arcadepunks.com
#3 1 year ago
I run Retropie with an RGB monitor. I play console games, not arcade games. But MAME is available for arcade games. You would need some kind of compatible HID USB controller for your joystick and buttons.
#4 1 year ago
My family gave me a diy picade for.my birthday. Find an image that has what you want and it should tell you what hardware you need
#5 1 year ago
Quoted from Crash:
Any idea of what i would need or where i could get it?
#6 1 year ago
I built a barcade with a pi and it's been working well.  It took a little finagling to get working right, but now that I got it, it's working great.
I used the "zero delay" USB board to go between my joystick/buttons and the pi's USB port.  I actually use two of them, one for player #1, one for player #2.  It was easier than the other, dual player, adapter board that I can't recall the name of at the moment.
Here's an example:
ebay.com link
Get the one that has the right size connectors on the wires for your button connection tabs.  I think there's two different kinds out there.
Keep in mind that more games is not necessarily better.  I've got so many games, it's like going to a restaurant with a huge menu, you can't decide what to play.  Don't over do it.
Looks like the pi 3B+ is the latest and greatest.  I run retropie, and it's fine for me.
https://retropie.org.uk/
#7 1 year ago
Are class 10 micro sd cards or class 4 msd cards better?
Is there any value to getting a micro sd card bigger than 32gb?
#8 1 year ago
Quoted from Daditude:
I got a Raspberry Pi 3b+ with a Canakit from Amazon:
amazon.com link »
I then installed Retropie and bought a custom harness for use with a modified TV using RGB SCART at 240p resolution.
https://www.avsforum.com/forum/64-direct-view-single-tube-crt-displays/2484081-rgb-input-hack-attempt.html#/topics/2484081
#9 1 year ago
I already have the complete cabinet, led screen, and accessories, so I got some hardware.
-Raspberry pi 3b+
-Class 10 64gb sandisk micro sd card
-Arcade Joystick and button kit for Raspberry pi 3
I have heard that arcade punks and retro pie are the way to go. Any suggestions?
#10 1 year ago
-Raspberry pi 3b+
I did a conversion last week with an arcade1up SF2 cab. Used the the ETA Prime instructions. Thought the most nerve wracking part would be drilling holes in the control panel, but just understanding the setup properly and finding ROMs and putting them where they should be to get it to work. Also had the wrong amp but found an RCA to 1.5mm jack converter in my 25 year old drawer of "possibly useful extra cables" so it all worked out.
Still can't get MAME to work, though. You'll no doubt watch 8 other vids because you'll encounter problems. Finding the right vids is tricky.
#11 1 year ago
Quoted from Guinnesstime:
Did you use retro pie?
#12 1 year ago
Yes
#13 1 year ago
I received my ras pi 3b+, class 10 64gb micro sd card, and 2 sets of joysticks with buttons and connections.
I downloaded playable roms from arcadepunks.com
Along with a fully working cab and monitor, I am hoping I can just plug and play.
I will keep it updated.
#14 1 year ago
I already have an arcade in which I am putting the ras pi in. My hope is to plug n play the ras pi with the joysticks and buttons I ordered, and use the current speaker system (which is very nice). I will also put on side art, a marquee, and a bezel.
I have cleaned the arcade inside and out and installed the buttons.
I hit a couple of snags, however. I need a specific light for behind the marquee. I also need a dvi adapter because the monitor has a 15 pin...so i need to adapt it for hdmi.
I have joysticks that dont line up with current screws, so i need to adapt that as well.
I will keep this thread up as a tutorial.
Of course, if anyone has advice, please chime in.
#15 1 year ago
Make sure you install joysticks in the same direction.
#16 1 year ago
Do you know how to set it up to accept 2 joysticks, or does it already do that?
I have recal box
#17 1 year ago
I have recal box
Not sure what recal box means? But mine detected 2 inputs (via USB) which you then configure.
I imagine this can be different depending on the kit, but I installed one stick "reversed." I put it in with the connector at the top of one, and the bottom of another. The Pi needed them facing the same direction.
No instructions w/my Pi kit.
#18 1 year ago
I used this light from Walmart to put in my Q*Bert cab. I think it's perfect.
https://www.walmart.com/ip/Hyper-Tough-18-Inch-LED-Slim-Under-Cabinet-Light/270897336
-Mike
#19 1 year ago
2 zero delay USB encoders
Pi 3b+
Arcade punks
Go for it! The fun is in the building.
For zero delay, as stated, both encoders must be set the same (so ie: if 2 = A on left,then 2 = A on right player).
I ebayed a marquee as well.
Keep us posted!
#20 1 year ago
Thanks for the help! I will report back
#21 1 year ago
Any USB led light strip would work for marquee. You can even plug it into the pi for power.
#22 1 year ago
I tried to run everything, but my monitor says there is no signal.
My monitor and ras pi are getting power, and my connections are good.
Did I download the software incorrectly??
#23 1 year ago
Anyone?
It seems from what i read that maybe it isnt detecting the hdmi input and i need to force it to use the hdmi. Any info is appreciated.
#24 1 year ago
Anyone?
Do you have it hooked up to a TV?
That’s what I use as my monitor first to get the Pi set up and enable WIFI. Helps because there’s a keyboard.
#25 1 year ago
Try a different amicable, or reverse the ends. Some cables are direction specific.
Added 18 months ago:
I just realized "amicable" was a spell check went wrong post.
It was supposed to read "hdmi cable".
#26 1 year ago
Quoted from RonSS:
It is a vga to hdmi connection.
#27 1 year ago
Maybe someone could tell me the steps to uploading on the sd card?
Im not sure if thats the issue, but it seems like a good place to start.
#28 1 year ago
Update:
I broke down and bought a preloaded card...which is still not working. My next step is to buy a 2.5 amp plug in. I am awaiting one in the mail. Hopefully that solves my issue. I have read that a lot of plug-ins dont have enough amperage.
In the meantime, I still need to finish getting the joysticks installed. I will also doublecheck the measurements for the marquee, bezel, and side art (all of which i have chosen the design, but i just need the correct size for ordering all at the same time)
#29 1 year ago
Here is how it looks currently:
#30 1 year ago
I have measured the marquee, bezel, and side cab for art. I ordered through a custom designer on ebay (since there are tons of possible sizes, I feel it is best to have them made custom to order)
We are Mario fans, so I got matching mario multicade arcade art (pic below)
#31 1 year ago
Honestly this is where I'd start troubleshooting first. Try hooking your set-up to a different display via HDMI only and troubleshoot from there.
#32 1 year ago
Quoted from roffels:
I got the higher amp plug in and tried it...no go. It is time to try another monitor apparently.
#33 1 year ago
Update:
I am getting close. I plugged it all in to a tv via hdmi cord. Boom! It started configuring!
Since I basically got everything else new, it is obvious the monitor/connection is the problem.
I am looking for a monitor on ebay/craiglist...but I may just get a new one and save myself the trouble.
This creates a new problem for me, however. My current monitor (the one that doesn't work with the ras pi) has 4 screw holes in the back that allow it to easily be mounted. It appears that some monitors have these and some don't. Im not sure if that is to attach a base or if it is for attaching it to the wall.
How do i know which ones have the screw holes? I don't see that info on boxes or listings i have seen.
On the bright side, my custom side art, marquee, and bezel should all be here in the next day or two.
#34 1 year ago
I believe that is called a "vesa" mount. I'll have to check, but basically, yes, that is so you can mount to the wall.
I just used a 32" tv for mine. Sounds as though if you are not going the "pro look" route, you could easily get away with a cheap tv. Opinions vary, or course.
#35 1 year ago
Update:
The screw holes can be used for either a wall mount or a stand. It’s a standard agreed upon by the “Video electronics Standards Association”, and pretty much any mount you buy now will support those holes in one way or another. Didn’t always used to be like that - you had to pay more for VESA compatible stiff
#36 1 year ago
Quoted from RonSS:
Quoted from Rdoyle1978:
Y'all are awesome. I will check it out.
I already have the mounting (from the non-working monitor), so i now need to get a 19 inch monitor or tv with hdmi input that is VESA compatible.
#37 1 year ago
I received the custom side art, marquee, and bezel. I have a TV that works now, but due to the cord attachment location...it has presented yet another issue: mounting the screen. I am in the middle of seeking out options.
If I were to re-do it, i would've started with the screen and gone from there. Unfortunately, I thought my original screen was good to go. It wasn't.
At any rate, I am getting closer.
If anyone has ideas on mounting the led tv inside the cabinet...please let me know.
#38 1 year ago
Give us a few pics and/or a sketch of what you're working with.
#39 1 year ago
Quoted from RonSS:
I originally had the sheet metal piece, but the hdmi plug in and power plug in do not have holes to go through. I have steel cutting scissors, but the metal is too thick.
I also bought 2 of the vesa metal wall strips...but they aren't flat...so that presents a whole new problem.
20190605_124844 (resized).jpg20190605_124856 (resized).jpg20190605_124908 (resized).jpg20190605_124922 (resized).jpg
#40 1 year ago
It seems that my current options are to either somehow buy a new tool and cut holes into the metal sheet or find a tool to cut or bend the metal bars to where they are flat.
Or...if anyone knows of a flat vesa attachment, that would work.
#41 1 year ago
Could you use something like this?
#42 1 year ago
Quoted from RonSS:
I used that stuff to put a pull-down fireplace TV mount where it should not have been able to go. Works great and available at Lowes or HD. P.S. You may want to invest in a cobalt drill bit.
#43 1 year ago
Quoted from RonSS:
Could you use something like this?[quoted image]
That looks like what i need. Could you tell me the name of it or where to get it?
#44 1 year ago
Go to Lowes/home depot type place. Check around the hardware/fasteners aisles, or ask an employee.
I agree with mcluvin, get a decent drill bit set, and a step as well. Looks like a cone sort of.
#45 1 year ago
Any luck?
#46 1 year ago
Quoted from RonSS:
These did not work. They require a specific size of hole, and those are too big.
Creating a wooden mount has been suggested, but i would prefer to try something metal first. I bought a couple of metal bracjets that are perfect, but they need sone metal trimmed off...which has been troublesome.
I have a flat metal piece that I pictured earlier in the thread which would work perfectly...but again, would need metal trimmed to fit the plug-ins.
I bought metal snips, but the metal is too thick, so i have been using bolt cutters (which are not nearly as precise).
I may just heat it with a soldering iron or a blowtorch and proceed to cut it from there.
#47 1 year ago
Creating a wooden mount has been suggested, but i would prefer to try something metal first. I bought a couple of metal brackets that are perfect, but they need some metal trimmed off...which has been troublesome.
#48 1 year ago
I bought some stronger metal snips (these are basically scissors for metal), and I was finally able to cut holes for the hdmi and power cords. I was then able to mount the TV.
My next step is to finish the blackout trim around the TV.
#49 1 year ago
Progress, always good!
#50 1 year ago
Is anyone using an x-arcade joystick with there raspberry pi / retropie setup?
Pinball Photos LLC
$ 9.00
Pinball Photos LLC
$ 7,700.00
The Flipper Room
€ 50.00
Creo Pinball
Rubber/Silicone
Scandinavian Pinball
£ 55.00
PinballToys
$ 109.99
$ 50.00
$ 299.00
Playfield - Plastics
Ramp-O-Matic
Filament Printing
$ 149.99
$ 9.99
$ 199.99
£ 79.00
PinballToys
$ 369.00
$ 28.50
$ 8.95
$ 259.99
$ 999.00
$ 69.99
PIN-UPS
$ 279.95
Pin Stadium Pinball Mods
$ 22.00
$ 19.00
Chrome Candy
$ 6.00
Cabinet Parts
Gameroom Mods
