(Topic ID: 201885)
Random Tilt and Phantom-Switches F-14 TOMCAT
By Defender_LXIV
6 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by kvan99
#1 6 years ago
Hello Guys!
I know my F-14 since I was born (15 years) and I love it since then! After 15 years we (my father and I) decided to restore the machine a bit (LEDs, new Rubbers, fix some Switches, etc...). We fixed the easy things and for the difficult problems we brought it to an expert.
But since then I've that horrible random Tilt from which many people are talking.
It happens nearly extactly like another Pinside user told (@Bok013). It happens when I play on the upper play field when I hit one of the TOM letters --> it Tilts and until I get the next ball the lights of one of the TOMCAT letters are going out.
But there is not only the Tilt that triggers randomly. There are many Phantom-Switches triggering when specific coils are working. Most of them trigger when pressing the right or left flipperbutton (EOS 15, 63). But also the left and the right sling (57, 58) and the bumper (28) provoke such a Phantom-Switch.
Often when I press the left flipperbutton the machine things that I hit the 'Kill Yagov' cave (55) without hitting it. But also the left + right drain (Kickback) (61, 62) + the Ball Shooter Lane (16) and the top left and/or right loop (47, 56) are triggering randomly.
Certainly the most annoying Phantom-Switch after the random Tilt is the middle and the upper ramp (31, 32) so that it shoots out the locked balls without having multiball. I think that this issue also comes when playing on the upper play field and hitting the right or left switch of the loop.
I am in e-mail contact with the expert where we brought our F-14 to and he speculates that one of the Chips on the MPU Board is not working anymore. He said that I should mark the Phantom-Switches on the Matrix and one line or column will be concerned. But when I mark the Phantom-Switches you can't see any pattern/line/column which could be concerned.
I uploaded the Matrix. The yellow marked switches are the ones wich are triggering randomly and the encircled switches are the ones wich provoke such a Phantom-Switch. (of course, there can be some faults in marking the switches but it should be roughly correct)
Does anyone has the same problem(s) and does anyone know how I can fix that problem?
I know, this sounds pretty difficult to fix but I would be very happy if you guys would awnser and tell me how I should go ahead with this problem.
(I apologize for my bad english skills )
Greets
Cedric
2 years later
#2 3 years ago
Quoted from Defender_LXIV:
Hello Guys!
It happens nearly extactly like another Pinside user told (Bok013). It happens when I play on the upper play field when I hit one of the TOM letters --> it Tilts and until I get the next ball the lights of one of the TOMCAT letters are going out.
Greets
Cedric
I’m having the same issues. Did you ever get this figured out?
#3 3 years ago
Bad resistor(+cap maybe too) networks in the switch areas of the MPU are fairly typical.
#4 3 years ago
Quoted from barakandl:
Great news. Did you have System 11 or 11A? I have an 11A which has 3 LEDs on the board. I think the resistor issues might be a little different between the two with this issue.
#5 3 years ago
Quoted from Lpilot1:
At some point an older board got put into my F14. I think it was out of a grand lizard so sys11? It has all the sound stuff in the top left area populated. Game would randomly tilt. Resistor network was replaced with discreet resistors and its been fine since then.
#6 3 years ago
I’ll have to ask my tech about that. Got a loss of ball tilt tonight.
#7 3 years ago
Second that....this is the most likely cause
http://techniek.flipperwinkel.nl/wms11/index3.htm
If your phantom switch problem is on the CPU board, don't forget to look at the 1k ohm resistor pack SR10 on the CPU board. When this resistor pack goes bad, it can cause intermittent phantom switch closures. Use your ohm meter, and test the resistor pack. If in doubt, just replace it.
It looks something like this
$ 1.00
Pinball Alley
$ 18.00
$ 5.00
Metal-Mods
$ 12.50
RoyGBev Pinball
$ 65.00
arcade-cabinets.com
Pinball Invasion
$ 69.00
Pinball Pimp
$ 39.99
$ 170.00
Displays
Digipinball Shop
$ 36.95
$ 18.95
Fort Lauderdale, FL
5,000 (Firm)
Vandalia, OH
$ 19.99
$ 54.99
This page was printed from https://pinside.com/pinball/forum/topic/random-tilt-and-phantom-switches-f-14-tomcat and we tried optimising it for printing. Some page elements may have been deliberately hidden.
