(Topic ID: 159669)
Ramp Optos - Stripped screw hole repair?
By markp99
7 years ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 7 years ago by markp99
#1 7 years ago
I have noticed the screw holes in the majority of my ramp optos are almost fully stripped (from the factory!). Nothing is falling off, but the mtg screws have nearly zero grip resistance.
What's the best way to improve/repair this issue for the long term?
#2 7 years ago
Without seeing the specific placement. Can you put a small bolt and nut in there place? Use washers where you can.
#3 7 years ago
This is the application, might be some room to add a nut on the backside. I was more thinking of somehow adding material to the hole to provide resistance for the screw threads.
#4 7 years ago
I'd probably remove the opto, and try to fill the hole with epoxy, then re-drill it slightly smaller. Not a pro at this, but that's my first thought.
#5 7 years ago
Looks like the ramp hole is actually a pass through and the threads grip the opto underneath. I would just add a small washer between the head of the screw and the ramp to even out any pressure and reduce fractures from any twisting. I could be wrong, but I don't think the screw should have real teeth into the ramp plastic.
#6 7 years ago
Is the screw loose in the ramp plastic or the opto plastic?
#7 7 years ago
Yes, the ramp hole is a passthru. There is no stress on the ramps from these optos whatsoever. It's the plastic threaded holes on the optos themselves that are the issue here.
The epoxy idea is kinda where I was thinking, but no clue what material to use. The final result would need to be removable to permit me access to remove the ramps in the future, etc.
#8 7 years ago
Maybe use hot glue to fill the hole at first? If that works... great, and if not, it should be easy enough to remove and try something like a clear cast epoxy (i.e. tape one side of the hole and fill it from the other side, let cure and drill).
Edit, or another option may be to just stick (or glue) a piece of a toothpick in the opto hole to give the screw something to grip.
#9 7 years ago
Did think of hot glue, but suspect it will not adhere to the plastic for very long.
I'll look for some epoxy type material that will not also "eat" the opto plastic.
#10 7 years ago
If it's not broke, don't fix it. Unless you're having to go back and occasionally retighten, I'd just leave it alone. MHO.
But if it is a problem, you might be able to sacrifice a $4 Horrible Freight soldering iron as a hot knife and build up the inside of the hole with a similar material. The trick is knowing what the material is to begin with. Then true up the hole with a twist drill.
If you don't plan on taking it apart again, a drop of lock tight might fix it. I would use the blue stuff as it isn't permanent.
My 2 cents... prolly double what it's worth. Best of luck.
#11 7 years ago
Quoted from browne92:
Yep, this has been my approach since I first noticed in Feb when I removed the ramps the first time. Clearly not broken, but screws held-in with barely a whisper of resistance just don't give me the same warm fuzzy of a nice snug attachment.
$ 109.99
NO GOUGE PINBALL™
$ 259.99
$ 54.99
Advance, NC
$ 39.00
Arcade Upkeep
$ 39.95
Hookedonpinball.com
YouBentMyWookie
8,500
Tuscaloosa, AL
10,995
West Chicago, IL
$ 24.95
$ 29.99
PR Mods
$ 49.99
Milford, CT
$ 11.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/ramp-optos-stripped-screw-hole-repair and we tried optimising it for printing. Some page elements may have been deliberately hidden.
