(Topic ID: 107609)
Total Lightshow. Development thread.
By TimeBandit
6 years ago
  • 2,271 posts
  • 249 Pinsiders participating
  • Latest reply 19 hours ago by Ashram56
  • Topic is favorited by 207 Pinsiders
Topic poll
“Is there such a thing as "Too many lights"”
  • Is there such a thing as too much luvin? 8 votes
    19%
  • Is there such a thing as too much good music? 6 votes
    14%
  • Is there such a thing as too much pinball? 29 votes
    67%
(43 votes)
There have been 443 images uploaded to this topic. (View topic image gallery).
There are 2271 posts in this topic. You are on page 45 of 46.
#2201 9 months ago
Just got a Metallica that has this installed. It is just superb. Had no issues with it but guess it makes sense to do the update above regardless. Cheers TimeBandit for such an awesome mod!
#2202 9 months ago
Quoted from ktm450:
Basically you just connect it via the switch matrix for the premium, tapping into the correct colour wires at connectors or using insulation displacement connectors. The motor taps into 20v at the pin where the premium does in the back box. Then switch the negative wire through a solid state relay such as an SSR-25DD (heaps on eBay) the relay is switched from the outputs on the total light show board.
Thanks for the information!
In regards to the output on the TLS PCB... is it the unused "OUT5" and it's associated "GND"? If not, what connection is it?
Thanks again.
[edit]
Found the answer. For future reference there is good information starting at post#837 in this thread...
https://pinside.com/pinball/forum/topic/ramp-lighting-in-your-face-st-pro-brought-to-lifevideo/page/17#post-2879534
#2203 9 months ago
Quoted from TimeBandit:
I have also just added a fix for the errant cross-raising. Again, let me know if it plays up again.
Can confirm this has definitely fixed the problem. It used to stay up if I started a game just after finishing the prior game, when unforgiven starts playing and the cross has just risen again. The very start of ‘attract mode’
If you let the section of unforgiven finish, it has never been an issue, only time it happens is when you start a new game just after it has risen.
Now it only stays up for the first ball then retracts again.
Thanks very much mate, good fix!
#2204 9 months ago
Patiently sitting on the sidelines waiting for dmd aprons ..... so looking forward to their return.
#2205 9 months ago
Any chance we will ever see a solution to the broken Metallica pro spinner sounds?
#2206 9 months ago
Quoted from gweempose:
I'm pretty sure I remember reading this is totally dead because of Stern closing the port? So much so, I uninstalled my Sound Caller setup and just connected the spinners to the left-most and right-most picks.
#2207 9 months ago
Quoted from ktm450:
Now that’s how you provide quality debugging feedback. Description couldn’t be clearer. Funny, when you’re testing these things you have to think of a whole bunch of scenarios that may eventuate. I had simply never thought to test what would happen if I pressed start a little early.
I’ll have new code this afternoon to fix that last niggle.
#2208 9 months ago
I’ll setup for someone to post the Jim Carey “there’s a chance” meme....
My kit can send a spinner sound trigger no problem. “All” it would take would be a third party sound driver, triggered by my board, that has an appropriate sound stored in it, that you could play back through the machine’s speakers. Hell, you could even play it externally to the machine if you wanted.
#2209 9 months ago
Can you step one level lower in abstraction to describe how this had been working through the SAM UART? Did the previously working serial connection simply take a command to play particular sound script?
#2210 9 months ago
Awesome! Thanks very much Mike!
#2211 9 months ago
Quoted from ktm450:
Ok, this should cover it..
https://drive.google.com/open?id=1MrLQeMY1JNswea3ubzVDgWklGniRCkhD
For anyone else looking at Met code. This link is the latest version.
#2212 9 months ago
Quoted from RobF:
Yep, simply sent a command to use the menu option "play sound" or whatever it was.
#2213 9 months ago
You could even build actuators to play double kick drum, and have an actual drum get played in time with the spinners.
Someone should do that.
#2214 9 months ago
And the issue is the newest update has disabled the UART? If we are lucky it is a simple config register setting that they turned off. With a little disassembly and detective work, it should be possible to build a rom patch to reenable it. If you want to talk shop and see if it's doable, shoot me a note. I have your sound board just wasting away in a drawer.
#2215 9 months ago
Quoted from RobF:
Ya. How many do I have wasting away in a drawer. Lolol. So sad it’s funny nowadays.
Generally I’d like to investigate it further but it’s beyond my pay grade. C++ is where I max out, lol. Any disassembly I do has to involve a screwdriver.
I did try attacking it with Olivier aka pinball browser, but even he, the king of ROM patches hit a wall.
I honestly think the path of a general extender unit that takes my triggers and does a whole bunch of other stuff is a better use of anyone’s resources.
#2216 9 months ago
Sadly I am better from the bottom up (somehow this phrasing doesn't sound right...haha) so I tap out with OOP constructs and run back to my load/store/shift safety blanket . I'll give Oliver a ping and see what info he has. You are probably right about building an extender being a better use of time. But losing the serial connection bugs me enough to see if there is a way to get it back.
BTW, glad to see you back at it.
#2217 9 months ago
Mike this has fixed the cross staying up as you can see in the start of my video. It momentarily makes the cross rise when the first ball hits the trough switch. Then drops it again when the new ball is on the shooter lane switch as you can see at the end of the video.
It doesn’t happen if you have started cross multiball during the first ball but it did happen when I got cross multiball on the second ball and drained, then when my third ball was in the shooter lane it lowered again.
It is usually only the first ball though, and only if the game is started whilst the unforgiven music is playing (if you let the short unforgiven music finish it does not have the issue at all), so all good, Nothing to stress about, great improvement!
Thank you very much for taking the time to fix it for the very limited number of people who it affects, I really appreciate it!
#2218 9 months ago
Quoted from ktm450:
Excellent!
One thing does always risk causing another of course, so I will look into the extra bits over the next couple of days. Great description though, should be easy to track down.
#2219 9 months ago
Excellent!
No stress at all mate, I really appreciate the updates, as I said it was something I could live with but awesome that you have taken the time to resolve!
#2220 9 months ago
Excellent!
I have done a bit more testing it has done a couple of weird things like rising and staying up during the start of sparky multiball. And it dropped a couple of times during cross multiball. (This has nothing to do with when I start a new game. It can happen randomly if I wait for unforgiven song to finish before starting or if I start during the song playing.)
As far as I can tell the ball one issues, when the cross rises when the ball drains and is in the trough and it goes back down when ball two is in the shooter lane, only happens if you start a game during the song unforgiven. As soon as that song fades out and relay 1 is engaged (Can hear it click), starting a game then has no issues (possibly something to do with relay 1 as if you quickly start a game before it disengages it doesn’t have the ball one issue either but can have similar problems on other balls)
I can certainly live with that if it’s too much trouble to chase out.
It is much better than before, where it sometimes stayed up for the whole game or until you finished cross multiball.
#2221 9 months ago
Another Metallica Pro has a rising cross thanks to TimeBandit(and Marco)! Thanks again Mike!
#2222 9 months ago
There’s going to be a delay getting the next TLS kits out for Tron and Met.
Over the past few months I’ve been having some issues with the main boards that have been very surprising and very hard to track down.
Turns out that there is a number of bad Atmel MCUs in the batch. The failure rate I’m seeing on these is outrageous, and having been working with my serious engineer buddies I have heard that in the last year they have seen similar problem batches in other Atmel chips.
This means I have to get the main chip replaced on every outstanding board. Don’t know the turnaround yet but I will keep you posted.
#2223 9 months ago
Dang that sucks. Could this explain the weird behavior I had with my TLS causing memory corruption on my Met? Would you mind sharing the gory technical details on the nature of the problems you are seeing?
#2224 9 months ago
Quoted from RobF:
The bit where it asks the question whether it needs to go to the bootloader or not, and what register it needs, gets scrambled. The symptom is that it powers up straight to the bootloader and gets stuck there.
1 month later
#2225 7 months ago
Worth the wait for sure!
#2226 7 months ago
Any update about this lightshow kit?
3 weeks later
#2227 6 months ago
New code! Haha. Here is the new Metallica code that addresses the sometimes-going-dark-for-too-long issue. Please let me know if it bugs out in any way. I will fix it straight away.
I played a couple games last night and the issue persists.
1 month later
#2228 5 months ago
I will soon acquire a Tron Legacy Pro, which has already been modded with fiber optics but the fiber control is not game controlled, it's a simple remote control type device which cycles through colors.
I would therefore very much like to change it to a more evolved version, but I'm having a hard time finding a solution, will TLS Tron units be back in stock anytime soon ?
Alternatively, is there an open source version that we could build ? (similar to Pinduino, but using fiber optics instead of ledstrip)
Thanks and regards
#2229 5 months ago
Any updates on availability for Tron?
#2230 5 months ago
Hi Mike, any update on the Metallica kits?
#2231 5 months ago
Quoted from jsyjay:
I may be selling my Metallica and I think I might make out better if I sell the kit separately. What is the kit worth?
#2232 5 months ago
Quoted from Shredso:
#2233 5 months ago
I would HATE to take mine out. It would take forever to remove.
#2234 5 months ago
Quoted from jorant:
I agree, it's gonna stink to get out. Especially with my low ceiling. I'm just not sure I'll get the value of the mods if I leave it in.
#2235 5 months ago
I paid 200USD, inclusive of shipping, for a new, not installed kit from an owner who never got around to installing it.
#2236 4 months ago
I wouldn't uninstall it. The Total Lightshow kit is one of those rare mods that I think you should be able to get your full money back on when you sell the game. It's a highly desirable mod, and it takes a long time to install.
#2237 4 months ago
Seems like the Met TLS would also help your game sell faster, the user experience is definitely enhanced. The only reason I would consider uninstalling would be if I had to sell Met for $ and knew I would be buying another down the road.
#2238 4 months ago
Is it safe to assume that the DMD aprons are not coming back? It's been a long time without any mention. Oh well, I'll have to spend my money on something else I guess.
3 months later
#2239 49 days ago
Is there a list for Tron?
#2240 44 days ago
I would like to +1 myself for the MET pro kit.
#2241 35 days ago
I remember asking to be added to the TRON TLS kit list about 11 months ago, but this would probably be a better place to ask since it won't get lost in the jumble of other TRON posts in that thread.
+1 for a TRON TLS kit please
#2242 28 days ago
One Metallica Pro Kit for me please. Thank you!
#2243 24 days ago
I would also like to be added to the Tron TLS kit.
#2244 24 days ago
Please put me down for a Tron TLS kit.
#2245 23 days ago
I don’t think there is a Tron TLS kit list, but if there is, just in case, +1 for me too please
#2246 23 days ago
I emailed and pm'd Timebandit a month or two ago and haven't heard back :/ Really want the tron ramp mod!
#2247 22 days ago
Given the lack of response, I've been looking at building mine. I have pretty much things nailed down, just hesitating on the control system.
In that scope, If anyone has the Tron LE full manual, including board schematics, that would help
Regards
#2248 22 days ago
Quoted from northvibe:
I did the same and I also asked to be put on the list on the TRON lovefest thread, before I found this forum thread. I have the EL wire set, but it's just blue and orange. I think it was a kit that was offered before the TLS and other ramp mods were available. His last post here is only 8 months ago, hopefully he shows back up with good news. Have to stay positive.
#2249 15 days ago
YES!!! I would like to +1 myself for the MET pro kit as well!! Last mod needed for my Met!
#2250 6 days ago
One more Tron TLE kit request here too.
$ 279.95
Pin Stadium Pinball Mods
5,400
Bakersfield, CA
