Quoted from TimeBandit:I haven't mounted it as far down as the ball drop. While I only have a limited amount of test equipment I don't want to go bending it up too much and that last turn is a little tight. The first video has it as far down as the beginning of the turn. That oviously brings the starting point down a bit. Final mounting will be at the discretion of the end user. The only stipulation is one of the holes lines up with the opto. I have 100mm lengths designed, but haven't built any, so in the end you could have the 600mm standard length with a 100mm extender clipped on which would give you backboard to ball drop coverage.
BTW, you should see how beautifully a 900mm three-strip length hugs the tron ramps..
Could you gently heat the strip and bend it then let it cool into shape? I've done that with these thick rigid led strips. Click the picture to enlarge and see how thick they are.
