Well, great news for the rising cross hopefuls. I received my cross mechanism today, and within a couple of hours had it bolted into place (it won't take you that long to install it. It took me that long to figure everything out) and successfully connected into the machine's switch matrix. In switch test, the two switches (cross up, cross down limit switches) on the mechanism correctly come up as #33 and #34 when activated. This means I can guarantee that I can talk to it through the Matrix Interceptor. I also tested powering it directly through the power outputs of the Interceptor (although I never planned on running motors through it) using one of my old boards. It only draws 300mA so I am comfortable doing it. The only issue is that because my power outputs are capped at 6.3V the motor rotates slower. It takes 11.5 seconds for the cross to rise fully.
I didn't do a full operating test with code as my sample board is back with the manufacturer.
So those of you who are thinking about it, see if you would be happy with 11.5 seconds' travel and then I can tell you that it is easy to install and I will support it. If you require the faster travel to exactly match the premium you would have to power it with 12V separately and then I would need to put a transistor in the line and trigger it with my output. I would need to build a little board to do that properly and the only benefit of all that would be the faster travel. Not so sure I'd be up for all that.
--edit: OR, idiot, I could just put a 12v step up converter in the line!
Testing the connection. The old static cross is still mounted there in the playfield..
Tapping into the switch matrix..
Another view of the switch matrix tap..
Connect the cross mechanism straight to the tap..
Some drilling required for mounting holes. They are different to the static pro cross..
A bit of a tight fit amongst the Pro's wiring harnesses..
