(Topic ID: 284001)
Ramp diverter problem
By rvermeire
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by rvermeire
#1 3 years ago
My ramp diverter to lock balls is not moving as it should.
Sometimes it stays left even when it has to lock a ball and should be right or stops in the middle and the weight and speed of the ball defines what direction it will take.
Guess this is something than can be adjusted ? Manual doesn't provide any help.
#2 3 years ago
Check that mechanism is clean, possibly replace the coil sleeve if it's never been done
Also, the flag has to be tight.... it's similar to a flipper just with a different end on it
#3 3 years ago
Quoted from slochar:
How to tighten up the flag (guess you mean the metallic part moving from left to right?)
#4 3 years ago
What game?
#5 3 years ago
It's mentioned in linked games... Whirlwind
#6 3 years ago
Somewhere around item 8 is where you'd check it.... not sure if there's a screw in there, if it's press fit it would have to be pulled and possibly welded/replaced. But anywhere in that mechanism if there's slop, it's just not going to be tight.
#7 3 years ago
Somewhere around item 8 is where you'd check it.... not sure if there's a screw in there, if it's press fit it would have to be pulled and possibly welded/replaced. But anywhere in that mechanism if there's slop, it's just not going to be tight.[quoted image]
There is indeed a little inbus screw around 8 which was a bit loose... I tightened it up but still the issue remains.
Despite the fact I thighten it up item 11 in the drawing can still easily be moved up or down...
The coil is still doing his job, the metal part is not doing what it should be...
#8 3 years ago
Up or down play (a little) is OK. You want it tight so that the linear motion of the plunger can be translated to rotational motion for the flag.
If the hole the plunger goes through is egged out it will need to be fixed with some kind of filler/bushing. Might need to fill it with something like JB weld and drill a new hole.
#9 3 years ago
Thx for tips will continue the search/challenge.. keep you posted.
$ 27.00
7,500
Bakersfield, CA
$ 90.00
$ 45.95
4,600 (OBO)
Greenwood, IN
$ 399.00
$ 95.00
Pinball Mod Co.
$ 899.00
3,800
Fort Worth, TX
$ 16.50
Metal-Mods
$ 18.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/ramp-diverter-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
