(Topic ID: 315723)
Radical! No solenoids working, help needed please
By Chosen_S
1 year ago
  • 23 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Chosen_S
#1 1 year ago
Need a little help please
I’ve lost all solenoids and flashers. I’ve done several searches here and the web with no definite path to fix this issue.
Q7 on the aux board is good, I tested the tab to ground and the AC relay is not switching.
What else do I look for?
Thank you for any help
#2 1 year ago
Q33 is good
#3 1 year ago
Fuses test good on the Auxiliary Power Board?
#4 1 year ago
Quoted from chad:
Yes, all fuses good, pulled them individually
In fact, all fuses in the backbox are good.
All voltages on the power board are good.
#5 1 year ago
Could be bad solder joints on the A/C select relay.
#6 1 year ago
Do you have voltage on on your coils? Tested the fuse on the underside of the playfield?
#7 1 year ago
Quoted from PinballManiac40:
There is correct voltage on the coils
Where is the fuse located? I looked all over, I know this machine pretty well, isn’t the fuse for the flippers?.... I’ll look again
#8 1 year ago
Quoted from Chosen_S:
Several system 11 games have a fuse other than at the flippers. I am really not sure Radical did so took a shot asking about it. Made you look. haha
Earthshaker has a fuse near the pop bumpers.
Since you have voltage at all your coils, fuses should all be good anyway.
#9 1 year ago
Shouldn't you be trying to short Q8 to ground on the MPU?
I have seen bad relays before where I had to tap on the outer case to make them work and were not solder related issues.
#10 1 year ago
I've had to pull the case off and move them , then they worked fine.
#11 1 year ago
Sometimes you can adjust the contact switches in the relay if they are not burnt.
#12 1 year ago
Came home to test this, i grounded Q8 on the mpu and the relay 1 on the auxiliary board does switch.
I held it in place and started a game and no balls kick out to the shooter lane and I have no flippers. I imagine that none of the coils are being allowed to operate
My displays are also only showing two digits on each display.
Some of my feature lamps or not operating as well., The ones that are operating, Are very dim.
#13 1 year ago
Can you post a picture of the MPU board?
#14 1 year ago
AD91771B-A29A-4A73-9763-9D914BF5F9B1 (resized).jpegAD91771B-A29A-4A73-9763-9D914BF5F9B1 (resized).jpegB2015DD2-D218-408D-BF97-6F93CBFC7161 (resized).jpegB2015DD2-D218-408D-BF97-6F93CBFC7161 (resized).jpeg
#15 1 year ago
This is sounding like your issue. C58 1uf axial 25v electrolytic
Also, replace C30, 22uf 25v axial electrolytic, as it can cause intermittent PIA failures during bootup.
#16 1 year ago
Thank you, I’ll try this and report back. I hope this solves the issue, I’ve had messed up displays on and off for a while as well, but this sounds too good to be true lol, and too close to the earthshaker issue the other fellow had!
#17 1 year ago
That C58 was trashed, looks like it’s been replaced before
7C83E479-CC7D-4DE1-B52C-67ADDFEBF338 (resized).jpeg7C83E479-CC7D-4DE1-B52C-67ADDFEBF338 (resized).jpeg
#18 1 year ago
This was the exact fix
Thank you PinballManiac40 ! Great find!!
#19 1 year ago
Very nice. If it is still working, please consider marking this thread as resolved at the top of the thread.
#20 1 year ago
This cap shouldn't be an electolytic cap. It needs to be a tantalum cap for a more precise timing circuit.
#21 1 year ago
Quoted from GRUMPY:
What value should the tantalum cab be here?
1uf,25v, or 50v?
#22 1 year ago
1uf,25v
This is what should be in the game. 50 volt rating is fine too. Remember this cap is polarity sensitive.
#23 1 year ago
Quoted from GRUMPY:
Thank you, I think the old cap went bad after replacement because it wasn’t spec.
$ 100.00
The Flipper Room
$ 23.95
$ 18.95
$ 27.95
$ 29.99
$ 27.00
Van Alstyne, TX
$ 19.99
This page was printed from https://pinside.com/pinball/forum/topic/radical-no-solenoids-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
