Radical club!!! only skaters welcome :)
(Topic ID: 134659)
By Delta9
  • 484 posts
  • 57 Pinsiders participating
  • Latest reply 59 days ago by soren
  • Topic is favorited by 20 Pinsiders
There have been 177 images uploaded to this topic. (View topic image gallery).
There are 484 posts in this topic. You are on page 10 of 10.
#451 81 days ago
Quoted from soren:
Juiced up right spinner will drain system resources.
That's what I get for lubing my spinners.
#452 79 days ago
Quoted from soren:
For the curious, here is a rundown of issues found on Radical.
All are fixed!
- RADICAL progress is never lost.
With a ball locked and some RADICAL progress, this progress is lost if the ball is nailed from the lock by opponents or tilt. Relocking basically resets the build-up to multiball.
- No multiball false start.
Two balls in lock trough, when the one was supposed to be ejected, will always start multiball.
- No incorrect end-of-ball, when draining down to one ball-in-play.
Two balls ejected to playfield, when the one was supposted to stay in the lock, will go to end-of-ball when draining down to one ball-in-play.
- A bug where Bust-a-move ramp shots would not register on fast combos, fixed.
- A bug where Tail slide ramp shots would not always divert the ball, fixed.
Part 1:
On Skate-or-die lit at start-of-ball, this is ignored on ball launch. So so wrong.
And even worse. The ramp logic stays like this into game play.
Until some unknown condition, where the game will accept Skate-or-die on ramp made.
Part 2:
Buggy diverter control can release the diverter too quickly. Before the ball would reach to it.
This also explains the false registering as a Bust-a-move ramp made, when the timing of events are divert->release->ramp made.
- Buggy X ramp diverter control with multiple up/down/up cycles on open, fixed.
This is related to the one above. May occure when the ramp enter roll under switch is closed several times per shot on the gate jiggling.
- Better postpond ball search handling when balls are held by the game.
When balls eject at multiball start, you only have about two seconds till ball search kicks in. Very dangerous for the controlled type players, because of...
- A bug where Mega-million would go to last chance (timing out) on ball search, fixed.
Yep. Too bad.
- A bug where the lower drop targets would stay down with no Spot letter option, fixed.
Lock a ball without making any lower drops. On new ball-in-play make all of the lower drops and wait for the Million to time out.
They will stay down till the ball walks an inlane. No Spot letter.
- A buggy light show procedure related to the lower drop target bank, removed.
Check out the flicker of the radicAL and Letter value indicators.
- Tail slider start level is harmonised at level 2 for all players.
Tail slider starts on level 3 (third ramp shot is diverted to left and mode ends) for player 1. For players 2, 3 and 4 it is level 1.
- A bug where Tail slider mode would carry half baked to next player, fixed.
The remaining tail sliders till mode ends, current run, is inherited from previous player.
- Tail slider exceeding level 15 no longer freeze the ball in the lock.
Completing level 15 constitutes a memory overwrite that can freeze the ball in the lock.
- Messy logic regarding RADICAL progress and RADICAL shots indicators are cleaned up.
RADICAL progress indicators chase light is awkward.
Shot indicators would occationally stay off after lock made.
- A bug where on tilt, the game would not shut down lights and music, fixed.
Make the bob tap against the ring. And then hold against the ring. The nudge tilt and the lift tilt procedures trip each other.
Is this all in this?
LA-1 patch 8351
#453 79 days ago
The bugs are all found in the LA-1 rom.
And they are all fixed in the 8151 patch, yes.
#454 79 days ago
Any way to patch the PA-3 Rom?
#455 79 days ago
That is a negative, I am affraid.
#456 79 days ago
Quoted from tdddddd:
You're running the prototype ROMs because you have a subway and a VUK?
#457 79 days ago
Soren roms on the way. Can’t wait to try it out. Good to go for tournament play?
#458 79 days ago
Quoted from ajfclark:
Yes. I added the VUK and the upper sling kicker and have been running PA-3 for years. It would nice to have these updates and support for solenoids 3A and 15.
#459 79 days ago
I imagine it is already incredibly difficult for soren to test against production machines, let alone reenabling features that were dropped from the prototypes. Maybe it's easier than I think though?
People have got the VUK and slingshot working with release software though.
From memory, people that just moved the snake run target to the VUK fork switch (#19?) had issues because the game didn't cope with it being held down. However, putting the switch in the subway itself and chaining the coil from the drop target reset coil seems to work I believe. You'd need to double check that in the mod threads on here.
The upper slingshot could just be directly switched, like an old EM slingshot, but it might not have much punch (though maybe that's not bad given the location) and I'd separately fuse it incase a switch got stuck.
#460 78 days ago
Yes
Yes, the power is about 10%, but perfect since the area doesn’t need full power
Also... yes, fuse this (I still need to do this)
#461 77 days ago
Quoted from soren:
So far so good, though I might update those labels with the patch number. I'll stream it in the next little while.
#462 76 days ago
https://www.twitch.tv/ajfclark
#464 75 days ago
Quoted from Darkwing:
Looks like it was STTNG?
The video labeled "Playing VPK" is actually the Radical stream.
#465 75 days ago
Awesome, Dude. Even with Radical udside down the game rocks.
#466 75 days ago
I moved to STTNG towards the end of the night... There's 3 hours of Radical before that.
Quoted from Clytor:
Yup, always forget to update something before I start. I'll update the video title.
Video will be here till Twitch kocks it off in a few weeks: https://www.twitch.tv/videos/333095864
Quoted from soren:
Awesome, Dude. Even with Radical [upside] down the game rocks.
It does! My play last night didn't, but I was handicapping myself a bit.
#467 75 days ago
Funny how alcohol can improve your playing skills. For awhile.
#468 65 days ago
Note. The patch has been updated on november 18. If your game says “LA-1 C8351” it is running the old patch.
Thanks to Free Play Florida and the raaaad broadcasting, an update to the Radical mod has been written. Features…
The kickback incident, fixed.
The Eschers dad incident, fixed. It was when the first ramp shot-free letter was the last “A”.
On (virtual) lock, with a ball already in the lock for immediate punch-out into play, the GI is kept on.
Tail slider is indicated as off at start-of-ball, if a re-lock is lit. The feature was infact off. Incorrectly indicated as available.
Radical
LA-1 patch aa9e
Download link: https://tinyurl.com/ycoakh9v
#469 65 days ago
Quoted from soren:
Radical
LA-1 patch aa9e
So now I need to Reburn my patched Rom you posted 2 weeks ago?, no problem, just wandering
#470 65 days ago
Quoted from Chosen_S:
Yes, and burn me a copy also
#471 65 days ago
Strictly speaking, this is an update offering the four improvements listed.
I recommend upgrading, but it is up to you.
And yes, it is both U26 and U27. And a patch for the factory LA-1 files.
#472 64 days ago
Quoted from soren:
I don’t actually own a burner, I paid someone to burn the roms for me and send them to me... anyone have an intuitive link to a burner and instructions so I can re-write my current roms?
#473 64 days ago
I'm using 27c256 EPROMs to burn the software and keep coming up with a U26 error. I don't know if I'm botching the patch or if I have some other issue. Anyone have a proven patched file they could send me?
#474 64 days ago
U26 is a 16 KB ROM image. A 27c256 is a 32 KB capasity chip. It is fine to use, but the image will have to be stored twice.
#475 62 days ago
Quoted from soren:
Thank you very much for your work on these roms
#476 62 days ago
I'm interested in purchasing a plug and play rom if anyone is producing them. Thanks!
#477 62 days ago
Quoted from SkaterVet:
Get in touch with Astill, he’s doing a great job producing roms
#478 62 days ago
Long story short, I finally got the software working. I was originally getting a U26 error with the first version of the patch. I don't know if I botched the patch or if there was some other issue. With the newest patch I finally started getting an Adjustment Failure error. I went in and out of test, then it worked. I had to put my game settings back in(freeplay). I don't know if this had to do with having NVRAM in it or not. Anyway, playing great now. Thanks soren
#479 62 days ago
On first boot-up with the new ROM installed, the game signals an Adjust failed (false alert). And Factory setting there after. After this any custom adjustments incl the new #50 have to be applied.
#480 61 days ago
Quoted from soren:
Do you suspect any more updates possibly?
#481 61 days ago
Suspect, yes. Hope not.
Radical just kept feeding more and more bugs. And with complicated logic to work on complicated mechs*, it was sort of evident that more stuff would turn up. And maybe will turn up. Despite heavy testing. Both laboratory test and general play.
For the first release, really only three things were not looked into. Bonus, the points speed-o-meter and kickback. Guess what, the kickback was faulty. That's Radical. I have since also looked into the bonus/bonus-x. It seems to hold up. Including the menu adjustable hold bonus feature (the lamps).
* Maybe not too obvious, but think about it. A spinner that is only supposed to be active when hit in one direction. That imposes somewhat of a dilemma even on paper, right.
#482 60 days ago
Quoted from soren:
Well, I appreciate all the hard work you’re doing, it’s going to make our fun game a great game
#483 60 days ago
Quoted from soren:
This is the right spinner, correct? and switch above it is supposed to give you the directions around the loop, but as we found, due to bouncing, misadjustement, etc it's not always reliable. I wonder if retro fitting an opto would be better or worse - just swapping one set of problems for another.
#484 59 days ago
The right spinner, there was a bug, which is fixed. Forget about that.
The issue with the spinner logic is, that if it spins long enough from a back to front ball movement, the logic will start to interpret it as a front to back shot. Reason for my cute remark that a spinner rule like this is not that trivial to implement.
$ 45.00
$ 27.99
$ 18.99
4,800 (OBO)
Evansville, IN
$ 50.00
PinSound
