So I got my Radical today, I turned the game on and played maybe 10 games on it. All was working well. Then I noticed the drop targets weren’t registering. I thought hey I’ll go through diagnostics. Started with coil test. Everything was fine until I hit coil 15 in which multiple coils locked, I shut the game off quickly but the damage was done. Q14 was burned up. Now that transistor feeds a coil that didn’t make it into production. It’s the upper sling. Now someone before me took the two larger red wires and the small brown with purple tracer and tied them together with a bullet connector. My guess is someone before me hadn’t done a coil test because it would have blown on them. I separated the wires and fixed the transistor q14 and q10. I’m still blowing the f4 fuse. No slings, no target reset. Could I have damaged something further down the line? Also snake letters and 1 2 3 inserts are glowing brighter than other lights making it hard to see whether they are solid or blinking. They are part of the same column in the matrix. Any help I’d appreciate it. I just want to play some Radical.
