Quoted from Quicksilver1:Oh not at all, I am not offended in any way so don't worry about that. Unfortunately I am a Just A Lover of playing pinball and Quicksilver is my favorite machine, and as I have stated before I am not very equipped at being a good pinball owner. I'm sure people like me are laughed upon constantly as a fool and his money are soon parted. This is just my favorite game and I thought I was purchasing something that would be basically trouble-free for a long time. But I am finding out being a pinball owner is a little tougher than I expected
I located the sale ad for your Quicksilver. I also located the sale ad for another scratch build Quicksilver that sold for big bucks. Both ads have pics on the lower side of the play field. You can compare one person's wiring job to another person's wiring job.
Even at its best, wiring can be a sloppy affair. If you have installed speakers to your computer, and added bluetooth, and added an external USB port, and added an extra monitor, and use a corded keyboard and mouse, you are probably familiar with the rat's nest of wiring that gets piled behind the computer tower.
Here is the other QS.
And now yours. It is not quite as neat. But everything works. That's what counts.
I also think 4-place drop target on yours is connected with a Molex connector. It is hard to say by looking at the pic, but I think you are in luck. If so, it will make your problem easier to fix. If the drop assembly is Molex then it will be easy to remove from the play field and place on a work bench. If you have a friend who can do some basic soldering, with that drop assy. on the bench replacing all 3 diodes will be an easy task.
While the drop assy. is on the bench, the holes in the play filed that did not line up can be filled with some dowel rod. Then when you replace the drop assy. you will need to install it using the hacked screws the builder used; Put it back the same was it was; The only thing different will be holes are now filled with dowel rod.
Now, what you can do is install replacement screws into the drop assy. flanges. You can either leave the hacked screws installed or you can remove them, although there is no real need to. But your drop assy. will now be screwed down correctly with screws in the flanges. Just don't use screw that are too long.
