(Topic ID: 230863)
Quick WPC GI question.
By jaytrem
5 years ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by jaytrem
#1 5 years ago
Last night I started fixing a few things on the Hurricane I recently purchased. 2 of the 3 GI circuits in the head were out when I started. After reseating the connector 1 came to life. I used my DMM to test the pins/fuse on the power board. Everything runs off of J121(chart is below), and I can see there was some previous work done in the area (pins 10 and 11 replaced). The feeds are on pins 1, 2 and 5. 1 and 5 test fine with the correct returns. 2 only tests okay with the returns from 1 or 5, it also tests okay with the unused pin 9 (should work with pin 8). So it looks like pin 8 is bad.
Now the questions...
Should pin 9 normally work? Or was that more likely the result of some work on the board? I'd rather not take the whole board out to look for a modification if somebody already knows the answer.
One option for a workaround would be to be to combine two circuits, I figure it should be fine power wise since the bulbs are LEDs. The downside to that is the light show isn't quite right. However if I use two feeds but have them use the same return, I think the light show would work properly. My question, how bad an idea is it to do that?
Thanks!!!
#2 5 years ago
You could have a cold solder joint on the back of the circuit board on the gi header
#3 5 years ago
I believe in making it right, and making the games work as they should. Each feed circuit has its own fuse, and each feed has its own separate return. Take the board out if you have to...I know it's a pain, but There could be burned traces there. You should repin anyway if you havent, even if the GI is now converted to LED. Making it right will make it last longer, and make it easier to troubleshoot in the future. Pin 9 should normally work.
#4 5 years ago
I wouldn't do it - one easy option is to swap 120/121. Check your fuses again, but remove a side or pull it out completely
#5 5 years ago
Quoted from WeirPinball:
Thanks everyone.
I did remove the fuse, wish that was the problem. Not sure what you mean by swapping 120/121. Could you elaborate? Thanks!
Bit reluctant to take the board out since everything else is working great. Probably the best thing to do in the long run though. Too bad they only replaced the 10/11 pins and didn't do the whole thing. Wonder if they damaged 8 in the process and didn't bother going back.
#6 5 years ago
Quoted from jaytrem:
Thanks everyone.
120 and 121 are both gi circuits tied together and the connectors can be swapped
#7 5 years ago
Here is the section in the schematics. Swapping the connectors might solve this if only a pin problem directly at the connector. You can also ohm this out for the connector continuity - check the pins for the feeds back to the fuse holder and the pins for the returns back to the triacs.
Screenshot at 2018-12-05 04-05-05 (resized).pngScreenshot at 2018-12-05 04-05-05 (resized).png
#8 5 years ago
Ahhh, didn't realize they were tied together. That makes sense now. Thanks again.
Quoted from wayout440:
Picture is worth a thousand works, thanks.
I'll test some stuff after work.
#9 5 years ago
No luck with the swap. Pin 8 to pin 8 test fine, but got nothing going to the fuse. Guess I'll have to take the board out at some point and see what's going on on the other side. The board does have a couple Betson stickers on it from 1996, so I assume they did some work on it. Also the MPU was replaced with a Rottendog at some point. The machine is super clean, so maybe a HUO and nobody bothered to change the batteries.
Thanks again for the help!
$ 9.99
Lake Elsinore, CA
$ 11.95
$ 54.99
$ 27.50
arcade-cabinets.com
$ 39.00
Arcade Upkeep
$ 27.95
$ 9.99
$ 9.95
KAHR.US Circuits
$ 1.00
Pinball Alley
This page was printed from https://pinside.com/pinball/forum/topic/quick-wpc-gi-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
