(Topic ID: 73359)
Quick tech question: Twilight Zone
By mab487
6 years ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by LTG
#1 6 years ago
During a game last night on TZ the slot machine stopped shooting out the balls. lifted up the playfield and saw this. looks like a wire has broken loose from the solder. never done any soldering so just wanted to make sure I am not making a mistake. Seems like the wire came loose from the coil and all that needs to be done is strip the wire to new and solder back on correct? Thanks as always!
#2 6 years ago
Correct. The wire has broken loose from the coil and needs re-attachment.
I had the exact same thing happen recently. Easy fix.
If you have access to heat-shrink material it has been suggested to re-solder the wire and slide some heat shrink over the entire connection - coil lug and part of the insulated conductor -
This will aid in reducing mechanical stress on the connector.
#3 6 years ago
Quoted from mab487:
Fanatic already answered.
If you are ever in doubt on a Williams DMD game. Go to tests-coils-stop on the coil in question. Hit the start button once, and then by hitting the + diagnostic button, this will step you through coil, fuse, transistor, and wire colors that go to each lug.
PinSound
7,200 (OBO)
Sale Pending!
Upper Freehold, NJ
