Im wiring some LEDs in parallel, 8 to be exact. Im using 12v as the power source and the LEDs need 3.3 volts of power and only use 20mA a piece. Im using a resistor calculator online, just because its a lot faster than I am. The resistor calc says i need a 2 watt resistor, but that doesnt seem right because the LEDs arent putting out but .528 Watts. Did i do my math wrong? Could someone tell me what i should be using or explain why its 2 watts instead of a 1/2 watt or 1 watt resistor?
Any Help is greatly appreciated!
Thanks,
deershoot3r
