So I'm finally doing some on and under playfield work on my Hollywood Heat and just started doing switch adjustments when I noticed something... odd. One of the slingshot switches is a brand new mechanism, wired in and everything, yet whoever put it in didn't actually FASTEN it onto its mounting bracket, so it's just sort of dangling in its socket. I'm amazed the slingshot has even been working considering. o_O
So my quick question is: Will any kind of screws that fit work, or do they have to be special? Or in either case, considering each switch is fastened in with two screws, would a quick fix for the moment be to steal a screw from another slingshot switch and just use that, then put a couple new screws in once I get some more parts?
