Air balls are notorious from the 2x and 3x targets on either side of the ramp.
I believe this to be a "Must Fix".
Om the Target that spells G-H-O-S-T, and releases slimer, some people get airballs, others do not.
I personally dont.
In creating a plastic that works, I have found for the ramp targets, in difference to others, a need to anchor it to the nut on the left captive ball.
A few reasons.
1) an un achored plastic on the left gets hit sometimes by balls going up the ramp.
This slows it down a bit, but also the loose end flexes up slightly, with hit.
I actually broke one test piece after around 20 games....it just hit it right to flex, and snap at anchor nut.
A benefit of this type, is it doesnt hit slimers butt on a full left swing.
I prefer, right now, 3 anchor points and on standoffs. It stops the airballs, has 4 solid points with the metal ramp.
the negative, its a bit bigger, and I am trying to shave away plastic, without degradation, so that a mandatory raising of Slimer is
not needed.
I am tidyying up a few looks, and Ill post pics, I think it will look good with or withpout a decal, but also as a nice place for ecto 1
above the artwork on the playfield.
For now, Im trying to gauge whether to cover the ghost target.
