(Topic ID: 140398)
Quick logic probe questions
By lukerp
7 years ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 7 years ago by lukerp
#1 7 years ago
Hi all,
I'm having some difficulties with my TSPP, and correspondingly picked up a logic probe. As I haven't used one before, I just wanted to ask:
1) Is there anything that falls into the category of big no-no with logic probes, such as "don't put it here or you're gonna have issues!"?
2) On a WhiteStar board, where would be a good place to attach the red lead for positive voltage? I see a number of ground loops, but didn't see any 5 volt test points.
Thank in advance.
Luke
#2 7 years ago
Honestly, I probably wouldn't go poking around with a logic probe, unless I had the board out on a bench power supply. A logic probe is only for chip level testing --> 0 to 5v. If you touch anything more than that, like coil voltage, it's going to fry the probe, and possibly damage something on the board. Also, its really easy to short two nearby pins with the probe tip with the slightest shake of the hand. So for me, leaning over a game, stretching to reach something on the game board with the probe, is just too risky.
Proceed with extreme caution.
#3 7 years ago
Do not touch your logic probe to the metal tab of the driver transistors or to a coil with 50 volts on it.
That will surely kill it ( as well as using it in the power supply where you have high voltages for the DMD, not good)
Also, yes be sure not to short adjacent pins when using it. Could cause trouble here and there.
You are pretty much safe using it on TTL ICs on circuit boards.
Cheers and good luck.
#4 7 years ago
Terryb is a pinsider that writes a lot of tech articles. He's got a great tutorial on this subject
http://www.pinballrehab.com/1-articles/solid-state-repair/tutorials/258-using-a-logic-probe
#5 7 years ago
Quoted from lukerp:
Modern logic probes will handle ttl and cmos, which covers a voltage range of 0-18 volts DC. Keep the probe off high voltage circuits (solenoid/flasher/dmd) and AC circuits.
My logic probe post on pinside covers a couple of pieces of test equipment (minigrabber test clip and DIP clip, which are not covered in the article above) that will make it a lot easier/safer when testing boards while installed in a game.
https://pinside.com/pinball/forum/topic/terrybs-guide-to-logic-probes
#6 7 years ago
Hey all,
Thanks for the information. Greatly appreciate it. I'll do my homework before getting started!
Luke
$ 52.99
Pinball Shark
Shooter rods
$ 19.95
Toys/Add-ons
7,900
Muskego, WI
$ 12.95
$ 105.00
Arcade Upkeep
Other
This page was printed from https://pinside.com/pinball/forum/topic/quick-logic-probe-questions and we tried optimising it for printing. Some page elements may have been deliberately hidden.
