(Topic ID: 217059)
Quick Draw Start button intermittently fails to start a game
By rar2667
5 years ago
  • 13 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by rar2667
#1 5 years ago
Hey fellow Quick Draw fans,
My Quick Draw sat in the basement for 25 years and I'm trying to get it going again. I don't have much experience in repair, but getting started learning. I can play several/many games in a row, then suddenly the start button will not start a game (with credits showing). I can lift the playfield and manually activate the S-Start Relay and a game starts as normal. Several more games may pass before it happens again.
I haven't tried to keep track of the match number when it fails, but is that anywhere in the circuit? That's the only thing I can think of that is random. I have checked the anti-cheat switches. Any thoughts on where to look next would be appreciated.
Thanks,
Andy
#2 5 years ago
Quoted from rar2667:
... then suddenly the start button will not start a game (with credits showing). I can lift the playfield and manually activate the S-Start Relay and a game starts as normal. Several more games may pass before it happens again.
I haven't tried to keep track of the match number when it fails, but is that anywhere in the circuit? ...
Match isn't relevant. When the problem happens, diagnose this circuit with Alligator clip jumper wires.
#3 5 years ago
Bounce and anti cheat switches should be your first suspects, clip around those and see if the issue goes away. zero position switch on credit unit another suspect. I usually jumper this as well to put the game on free play.
#4 5 years ago
Thanks for these troubleshooting steps Howard and pinhead. I'll get on these, but first I have to figure out what I did to my Player 2 score reel. I took it apart to clean and apparently can't get it back together correctly. Scoring 50 spins the 10,000 and other reels and makes a gear-slipping noise.
This line of work may not be my calling.
#5 5 years ago
Sounds like the plastic ratchet hasnt been put back in right .
#7 5 years ago
Thanks for those links, Howard, and Rolf was on the money about the ratchet assembly. Got that sorted out and the noise quit, but I still have erratic scoring on player 2. It must be on the 10s reel because when I get 50 points, the other reels spin unnecessarily. If I get 100 or 500, just the 100s reel moves and same with 1,000s, etc. I've looked at all the switches and they all seem right with the bottom one closing on Zero. There is a bit of a loose solder on the circuit board in position C next to 0. The solder is good but the rivet is loose in the board. Not sure if that could cause erratic scores?
Player 2 score reels usually don't reset either unless I tap the back of the score reel while the motor is running to reset. It's not the 10s reel that I need to tap to complete the reset, it's the 100s reel. Could that mean the coil is weak or getting stuck? Do I need to take the plunger out and change the sleeve?
Now I know why I've seen all the comments about score reels being a pain.
Taking a break and will try again. Thanks all.
#8 5 years ago
Hi rar2667 ,
Welcome to pinside!!!
Pick one symptom, slowly & thoughtfully diagnose it, and only then repair it.
... Player 2 score reels usually don't reset either unless I tap the back of the score reel while the motor is running to reset. It's not the 10s reel that I need to tap to complete the reset, it's the 100s reel. Could that mean the coil is weak or getting stuck? ...
Each score reel contains 2 switches that control its reset. One switch tells the reset circuit it's OK to move on to the next step in the sequence, and the other switch tells the reel itself to stop turning. Here are those 2 switches in their circuits for the 2nd player 100 score reel.
I see lots of posts from people who say this or that part is a pain (Here's where the AS and Interlock relay haters chime in to say how wrong they think I am). I don't agree with any of them. Work slowly and carefully, keep a good sense of humor, take breaks when you need to (good instinct there) and soon the machine will settle down and play reliably for a long time. Before long you'll almost wish something would break so you could fix it!!!
If you'd like a phone call, PM me your contact information.
H.
#9 5 years ago
Thanks HowardR for all the advice and the schematic. I did a little more work on the P2 reel switches and things are a little more stable. It occurs to me that I might not know the basics of "cleaning" a switch. I worked on them with a fine nail file, but upon closer inspection they are pitted and rough. This machine sat in my damp basement for 25 years, so there is probably corrosion on all surfaces. Probably need some advice on proper cleaning of switches.
I also tried to tighten up the loose solder joint on P2 10s reel board (photo attached), but my solder skills are not the best. Let me know if that solder contact can cause any of the problems I'm having. As it stands, when P2 scores 50 points, the 100s advances 500 points as well. On P1, sometimes a drop target only scores 400 instead of 500. Those seem to be my only scoring issues now.
I won't be able to work on the machine until Sunday, but I'll PM you my number in case you get a chance to talk.
I appreciate your efforts.
Andy
#10 5 years ago
I also tried to tighten up the loose solder joint on P2 10s reel board (photo attached), but my solder skills are not the best. Let me know if that solder contact can cause any of the problems I'm having. As it stands, when P2 scores 50 points, the 100s advances 500 points as well. ...
1. Until you get a lot more experience, only clean or otherwise repair what careful diagnosis tells you needs fixing.
2. Your solder joint looks nice and shiny which is perfect.
3. Re 50 giving 550, the 9th Position switch on player 2's ten point reel is probably always closed.
#11 5 years ago
The pic depicts the match or high score credit award board (on the reel), nothing to do with actual scoring itself.
#12 5 years ago
Quoted from HowardR:
HowardR nailed that one...adjusted the 9th position switch and extra 500s went away. Thanks for the tip.
#13 5 years ago
Hey guys...this looks like it has to do with the score motor not stopping in the right spot sometimes...causing the problem with the start button. Not sure if there is a switch controlling that or what? Any thoughts on how to troubleshoot?
Space Coast Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/quick-draw-start-button-intermittently-fails-to-start-a-game and we tried optimising it for printing. Some page elements may have been deliberately hidden.
