I'm looking for some support with my Gottlieb Quick Draw EM.
Symptom: I start the game and everything works as expected until my ball falls into the ball trough at the end of the my first ball in play. That's when the issue appears. The first player 100 point scoring reel just continues to tally up points and will not stop. I shut the pinball off and then turn it back on. The scoring reel stops but the score motor runs continuously so the game won't reset or start.
Resetting the pinball: To get the pinball to reset, I shut the pinball off, reset the total stepper motor to the zero position and then restart the game. Everything resets as normal and allows me to start a new game. The issue reappears when ball 1 falls through again to the ball trough.
I don't believe there is an issue with the score motor. It seems to be waiting for a signal to stop. This is evident when I manually move the total stepper motor to the zero position. I was suspecting the total stepper motor because it's always on the #3 position. However, it could also be waiting for a signal (technically it should be in the #3 position at the end of ball 1) so I'm starting to talk myself out of that idea. Me resetting the total stepper motor back to the zero position might be resetting everything and masking the true location of the problem.
Now I suspect the root issue has something to do with the 100 point reel running continuously. I need to order the schematic to this machine to see all the signals that create 100 point scoring then work upstream from there to try to identify faulty switches/wiring.
Any advice anyone can provide would be greatly appreciated. Thank you in advance.
