(Topic ID: 298398)
Questions before Starting
By MightyGrave
2 years ago
    #1 2 years ago
    Hey guys,
    for my homebrew project I got the my cabinet and had plannend my playfield and the shots I would like to have with vpx about six months.
    Now I will give it a try and "just start".
    But before I start my project and buy a bunch of parts, I have a couple of question for the coils and boards:
    I'll use following Board-Setup:
    1x P3-Roc (Multimorphic)
    2x PD-16 (Multimorphic)
    > 1 Trough
    > 1 Auto-Fire
    > 3 Flippers (Dual-Wound)
    > 2 Slingshots
    > 1 Scoop
    > 1 Droptarget-Bank
    > 2 Single droptargets with "fall down mechanism"
    > 1 Single droptarget
    > 1 Diverter
    > 1 Appering Post
    > 1 Ball lock mechanism
    > 1 Knocker
    Not shure which board I've to use for the shaker Motor 12-24V? PD-16?
    My first questions about the coils in relation to the consideration of the voltage supply revolves around which coils I should use for these mechs and why.
    > 3 Flippers (Dual-Wound) 11629 or 11630 - I not shure if 11630 is enough for two medium step ramps?
    > 2 Slingshots 26-1200
    > 1 Scoop 23-800 (is preinstalled)
    > 1 Diverter ??? - nor shure which coil is enough to open and close an diverter - should be the smallest working coil for this usecase
    > 1 Appering Post - 2 Versions of this mech (Stern / Willimams) 26-1200 or AE 27-1200
    > 1 Ball lock mechanism - ??? - A underplayfield "Gate" which opens to release balls - not shure how I build this gate and which coil would needed.
    1x PD-LED V3 LED (Multimorphic)
    > 30 GI LEDs (WS2811 "christmas light)
    > 40 - 60 Inserts (Fast LED)
    > 8 Backboard LEDs and some "other stuff" (RGB WSxx Chips)
    > 6 Flashers (5v Led Flashers)
    I hope that board is enough to run 3 different chain and change color for each individual Led. I have to watch videos from jabdoa to understand it.
    Or is there a alternative for this board ?
    And I'm not shure how I use flashers? - Directly on the PD-Led Board and power from the 5V?
    5x SW-16 (Multimorphic)
    > 60 Switches (Targest, Rollovers, Slings, Coindoorbuttons, Flippers, Eos, and so on....)
    > 16 Opto-Pairs
    Should be enough (4 boards for playfieldswitches and 1 board for the cabinet).
    2x SW-16 Opto Controller Board Assembly (Anarchy)
    > 16 Opto-Pairs
    Is it perhaps easier to separate the optos for debugging and error analysis from the pure switch boards?
    1x Power Distribution Board V2 Assembly (Anarchy)
    > 48V + 12V + 5V powersupplys all over this board
    Hope you guys can help me with the Coil and LED questions.
    Thank you
    Mighty
    #2 2 years ago
    Quoted from MightyGrave:
    > 1 Trough
    > 1 Auto-Fire
    > 2 Slingshots
    > 1 Scoop
    > 1 Droptarget-Bank
    > 1 Single droptarget
    > 1 Diverter
    > 1 Appering Post
    > 1 Knocker
    You can use the PD-16 for the shaker as well. I guess you could even drive it at 48V with PWM. Ideally you use a separate bank for 12/24V if you use a PD-16 (because of the fuse per bank).
    Should work this way. If you only want to run serial LEDs there are other boards such as the fadecandy. However, non of them is able to drive 5V LEDs/flashers directly.
    > 16 Opto-Pairs
    That sounds like a high switch number. Most machines I have seen only need 4 SW-16.
    > 16 Opto-Pairs
    Makes sense to have some kind of opto driver pcb. You do not technically need those but they will make your life much easier.
    Generally, I would check the manual of a machine where those mechs have been used and go with what they used. Those should all work and you can tune them in software later.
    Jan
    #3 2 years ago
    Thanks Jan,
    about the fadecady i talked with Philipp. I have to See it in persona to understand how it works.
    With the switches i'm Not sure how much I need for the gameplay Logic and mechs i want to use. I will list my mechs and Count all switches.
    The flasher could be 12V or 5v doesn't matter, Not sure whats easier to integrate.
    For the coils i looked in different machine Manuals and in some Threads Here. Should bei Working.
    best regards from the hanover region
    Sven
    This page was printed from https://pinside.com/pinball/forum/topic/questions-before-starting- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
