Hey guys! So I've been using Vid's guide to clean the playfield of a pin I picked up, and I'm running into some difficulties. I'm using the Magic Eraser + Alcohol method, but I'm thinking that I'm being too delicate. After an initial clean up, I noticed that the method hadn't really picked up dirt from the ball dimples, from areas around the mylar, or in vertical grooves in the paint. Any recommendations on how to dig that dirt up? Also, should I be replacing the mylar outright, or is there a method to cleaning that area?
Additionally, I noticed that three of the inserts sit slightly above the plane of the playfield. Is this common for early 80's pins? Is it something I should even address or is it fine?
Thanks in advance!
image0 (resized).jpgimage1 (resized).jpgimage2 (resized).jpgimage3 (resized).jpg
