(Topic ID: 161719)
Question re Dr Dude lights
By Pip
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 3 years ago by lukex
#1 3 years ago
on dr dude there are three colored lites on the top right of playfield--yellow, red and green
only the yellow one works...i changed the bulbs in the other two but it didn't help, they are still out and the bulbs are good...could this be a fuse problem? if so, which one? if not, what else could it be?
thank you
dr dude owner
#2 3 years ago
first check the sockets for good connection
#3 3 years ago
Could also be bad diode, if the socket isnt the problem
#4 3 years ago
Have a look at the lamp matrix and see if the non-working ones are in the same row or column.
Page 2-38 and 2-39 in the manual.
#5 3 years ago
Quoted from terryb:
and if they are in same row?
#6 3 years ago
Broken row wire. At one of those lamps or the one before in the daisy-chain.
Note they are not necessarily wired in the same order as shown on the matrix.
#7 3 years ago
i have basic pb knowledge, is this something i can fix myslef or do i have to call a repairman?
#8 3 years ago
If it is a wire as Terry says, it will be obvious when you look at/pull the wires to those lamps.
Easy job if it is just re-soldering a wire.
If you are unsure where it attaches, just look at the other lamps in the string that are intact.
Gweem's Mods
$ 59.00
Pinball Sales
PinSound
$ 12.00
PinWoofer
€ 95.00
FlipperLED
$ 27.99
$ 40.00
$ 84.95
PinBoss Mods
2,700 (OBO)
Silver Spring, MD
