I'm starting to troubleshoot the resetting problem that happens occasionally when both flippers are pressed. I bought it this way, so first read some info from the following like. (P.S. - I love the links at the bottom of this site for help http://www.marvin3m.com/fix.htm) I like it for a beginner, it really helps. This may be a bit long-winded so bear with me.
My question is not about the flippers yet...I replaced the AA batteries in the CPU board because there was some corrosion from the batteries when I bought it.
I used Deoxit from Radio Shack to remove the hardened battery acid from the terminal leads, which worked pretty well. I've used it on other electronic components, so unless someone says NOOOOO!!! I think it works well. It doesn't look like the acid screwed anything else up. To get the game to play, I needed to add service credits with the coin door buttons because the dead batteries keep resetting the game to factory settings.
Now I turn the game on, and when I first opened the coin door the test menu went straight to bookkeeping and started scrolling through the options by itself, until it reaches the end of the bookkeeping menu options. This happens right after the test mode displays the date & time need to be set, and this is the only warning. Like someone was rapidly pounding on the scrolling buttons it scrolls to the end of the bookkeeping menu and just keeps beeping, it's impossible to back out of the menu. I closed the door because you couldn't navigate the menus this way at all. I was just going to set it to free play and the date & time. I loaded the game up with 10 service credits, because it stops scrolling if you close the coin door and reopen it. The volume can be adjusted, but you can't get it out of attract mode, basically like the enter button (the coin door button on the far right) doesn't work. Looks like all the leads under the buttons are connected. I played for about an hour with no reset at this point. Even trying to reproduce it, couldn't get it to happen. (I'm assuming this will happen again.) Occasionally while the door was shut, you could hear the game trying to add service credits over 10. This stopped after short time.
Could just changing out the batteries fix this resetting problem? Is this is in the continuity of the watchdog chip on the CPU board, if the game is on? (Which I'm figuring is dropping below the 4.7V to cause the reset. So I'm thinking the problem deeper.)
My second question is does the interlock switch on the coin door need to be activated to get into the test menus? From the manual it mentions this breaks the connection to the 50V and 20V winding of the secondary transformer, so I don't think this has anything to do with the coin door button problem. Looking like a problem with the "enter" coin door button or the "Up" (+) button. I guess the switch for it enters the menu options, then it just continually scrolls to the end of the bookkeeping menu.
Sorry this is long-winded, but seems like I have a few things going on at once here.
