(Topic ID: 237133)
Question on IDC connector replacement
By Calipindave
1 year ago
  • 15 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by robertmee
#1 1 year ago
Hi guys. I’m going to replace a number of the IDC connectors in my EBD with molex style.
A number of the IDC wires loop through the connectors. These wires must be daisy chained and continue on elsewhere.
How do I add a pin style connector on the end of the wire and handle the other side of the wire that continues on?
Does this make sense?
Dave
#2 1 year ago
Quoted from Calipindave:
Dave
Put 2 wire ends into one crimped pin.
Have done this many times, esp rebuilding GI connectors on games like T2.
RM
#3 1 year ago
Quoted from RussMyers:
RM
Thank you Russ. I get what you you are saying. How can I fit two wire ends into one crimped pin. Aren’t the molex pins size dependent on the wire gauge. Will the crimp fit around the insulation of both wires. ?
Dave
#4 1 year ago
Or you can split the single wire into 2.
Whichever you like best.
#5 1 year ago
I would suggest a ratcheting crimper. Will make this project that much simpler!!
#6 1 year ago
Quoted from heni1977:
Definitely getting one. I have crimpers without and know that the job will be better with.
Dave
#7 1 year ago
Often 2 sizes of female crimp connectors are available.
Maybe like 22ga and 18ga.
So use the larger gauge (18ga) if you are crimping 2 wires in the same contact.
Molex does not officially rate those crimps for 2 wires, but I've done it many times.
Crash course in crimping:
https://pinside.com/pinball/forum/topic/vids-guide-re-populating-playfields#post-4545041
#8 1 year ago
Quoted from kpull:
I have done this many times.
#9 1 year ago
Quoted from vid1900:
Thank you vid and everyone.
I have some crimp contacts rated for 18. I will see if that works.
Dave
#10 1 year ago
I don't like crimping two wires into one pin. Especially on GI connectors that already use 18awg wire. A better solution for me is to solder a second wire to the pinned wire with appropriate heat shrink.
5 months later
#11 1 year ago
I have a small intermittent issue on my CFTBL whereby the first 'S' in KISS will occasionally go dark and by wiggling the connector wires it comes on again and works for awhile and then will go dark again. I would like to replace the IDC connector with a Molex type connector with Trifurcon pins to provide a more reliable connection so that the first 'S' lights up 100 percent of the time when it should.
Three of the loop through wires on the IDC connector were very frayed (only one strand was not broken) so I spliced, soldered and heat shrink wrapped the 3 damaged wires and punched them back into the IDC connector. After performing this repair I am still having an intermittent problem with the 'S' not lighting up on the KISS inserts.
The PCB tests out fine without any continuity issues on all 8 pins so I have ruled the board out as a cause of this intermittent problem. Prior to replacing the IDC connector with a Molex type connector I need some advice on how to handle the 4 loop through wires on this connector.
Do I crimp two wires into one pin or is there a better solution?
Gord
#12 1 year ago
Wiggling the connector and the fact it works awhile then stops indicates to me a cracked solder joint on the header pin on the board. Heat cycles cause that joint to expand/contract.
Pull the board and reflow all the header pins with some fresh solder.
#13 1 year ago
Quoted from robertmee:
Thanks Robert. I will post a follow-up after re-flowing some fresh solder on the header pins that drive the first 'S' on the KISS PCB and testing it out.
When I used a DMM to test continuity on the board it all tested fine, but it sounds like the heat cycling through the header pin joint is causing the intermittent issue due to the solder expanding and contracting. Would this be correct?
Gord
#14 1 year ago
After playing 5 games the first 'S' in KISS lights and stays lit when it should be lit. This is a small sample test, but prior to re-flowing solder on header pin 1 of the KISS PCB the first 'S' would flicker and go dark in 1-2 games.
Prior to re-flowing solder on header pin 1 of the KISS PCB I performed a visual inspection of header pin 1 with a magnifying glass and I could see that the solder was slightly cracked. I believe that re-flowing solder on header pin 1 has fixed my issue.
Thanks again Robert.
Gord
#15 1 year ago
Glad it seems to have solved your issue.
Gweem's Mods
$ 149.95
Allteksystems
$ 99.00
Arcade Upkeep
