Got a world poker tour that's being weird. The main problem is that the game keeps ejecting all the balls out of the trough. Even when you put them in when in test mode, they still eject out. Turn the game off, turn it on, start a new game, they eject out. This is not an issue with the trough or ball jam switches; they're registering correctly. It also has a sub problem of thinking the ticket opto switch is on, but I don't care about that. The service bulletin says multiball may last forever. I can't tell if that's the issue here. From the way they wrote it, it sounds like it should end when you turn the game off and back on. That it only happens when you've had a multiball. Does anyone have more info on this?
