I see this a lot. Is a home use only machine just one that's never been on route or something?
OR is there a special make of a particular machine that makes it a HUO? Like no coin mechs or something?
Quoted from Blackbeard:I see this a lot. Is a home use only machine just one that's never been on route or something?
Yes it is just a machine that has not been out on route. Which means it probably has much lower plays on it than a routed pin.
In most/all cases someone keeping it in the home all it's life will not see as many difficulties as a routed machine. I suspect my machine was HUO, but there was no way to confirm so that wasn't claimed.
I know I don't have enough friends to give any machine, even MM enough action to equal as much as an arcade/pizza joint.
Mine has no lock on the coin door area, just a knob so I can easily get into it, but I don't think that's a commonplace thing.
Yes, HUO machines tend to be in a lot better condition than machines that have been routed out in arcades, bars and fast food joints. There's no lingering smell of beer or tobacco inside the cabinet (unless the last owner smoked whilst playing at home) , and have less dents or scratches in the cabinet/backbox too.
As has been said, normally a HUO machine has been played a lot less than one out on a route, and has been cleaned and looked after a lot better, so the playfield is usually in a lot better condition.
Am I correct in saying that some of the more recent Sterns delivered NIB to collectors have turned up without any coin mechanism fitted to the front door?
It is the difference between buying a used car from the original owner verse buying a used cad from a cab company.
Quoted from TaylorVA:HUO is over used as a term to describe condition.
I agree, like routed then put into a home and that makes it's current status HUO.
Quoted from Loupie:I agree, like routed then put into a home and that makes it's current status HUO.
Anyone doing this is trying to pull a fast one. 99% of true HUO pins you can tell right away just by looking at the shooter lane. I've had some people try n sell me games n trying to pass them off as HUO and if you've been around this hobby long enough you can tell right away if it is or not.
HUO could also mean more when picking up newer sterns since the clear is not as thick as past pins. My AFM I bought from an op and it had a credit meter inside the coin door and it had over 24k games on it and it looks fantastic since after about 2 months he installed the upgraded scoop and cleaned the playfield n changed the balls every 3 months. The playfield shines better then the IM I unboxed in may of this year.
Don't be afraid to buy older pins cause they aren't HUO just be sure to inspect the major wear areas.
This page was printed from https://pinside.com/pinball/forum/topic/question-about-huo-machines and we tried optimising it for printing. Some page elements may have been deliberately hidden.
