Quoted from Pinball-DOOD:Okay! So I have circled which ones I can’t get a reading on in the attached picture. All other resistors read 10 ohms. I have replaced one of these before.
You cannot measure resistors while they're in a circuit. Everything else on that board (caps, chips, other resistors, etc.) with any continuity to the resistor will be electrically parallel, which will cause lower and possibly erratic readings.
You must remove, or at least lift one leg, before measuring can be done with any degree of accuracy. That's likely the reason you're seeing 10 ohms for everything... they appear to be in parallel so you're reading through all of them at once.
Quoted from Pinball-DOOD:I do happen to have replacement resistors, would these be suitable for replacing the 4 I can’t get a reading on?
As far as replacements, they are not replacements unless the specs match. Check the schematic for proper value, tolerance, and wattage. Check the spares to make sure value is the same (matching color stripes), it's the same or better tolerance (the last stripe), and that it's the same or higher wattage than the original.
In this case, I don't know what "can't get a reading" means. You should always get a reading. An open circuit is infinite resistance, and a short circuit is zero ohms. Both of those things are valid readings, plus everything else in between.
