Hey all,
Turned on my QoD today and the backbox GI was out. Checked all over for loose connections and no luck. The backbox lighting fuse was ok but was over-amped. It was a 15 and should be a 10. Any ideas? Thanks!
Incorrect amperage on fuse may have blown bulbs instead. Have you checked to see if the bulbs are still good?
Plugs tight?
Is it score only or gi as well?
Even though the fuse checks good make sure the fuse holder is making a nice tight connection and current is flowing. Also unplug the backbox jones plugs and plug them back in. They may not be making good connections either.
Mike V
Fuse holder is very tight and the bulbs are good. Jones plugs probably need cleaning! What is the best solution for cleaning them? 91% alcohol?
Quoted from Pinball-DOOD:What is the best solution for cleaning them? 91% alcohol?
600# sandpaper.
Sand paper as mentioned above or a green Scotch Brite pad (I use the pads as they create less dust). Scrub scrub scrub. They normally don't need a liquid.
Fuse and plugs are most likely suspects. Post another photo a little higher up on the lamp side to be sure (need the whole circuit for the backbox lamps).
Quoted from bingopodcast:Fuse and plugs are most likely suspects. Post another photo a little higher up on the lamp side to be sure (need the whole circuit for the backbox lamps).
Hope this helps!
Test a few of the bulbs in the backbox.
You may have blown out the whole string with an intermittent short to the solenoid circuit. I've seen this happen before.
Quoted from bingopodcast:Incorrect amperage on fuse may have blown bulbs instead. Have you checked to see if the bulbs are still good?
Yep, I'm back to that as well.
Do you have 6V AC between the black-white and white-red wires (the 6V supply lines) in the backbox?
/Mark
Check your tilt relay. In normal operation, the tilt has a NC switch that powers the lamps. In tilt, the lamps should go off and the tilt lamp should lite.
Quoted from bingopodcast:Check your tilt relay. In normal operation, the tilt has a NC switch that powers the lamps. In tilt, the lamps should go off and the tilt lamp should lite.
Gotcha, thanks. What would a tilt relay in an EM look like?
Just like that!
The switch in question is a SPDT switch - the NC side is when the relay is not tripped. The NO side is activated when the game is tilted.
There are other switches in there - the schematic will show you the wire colors - White with a red tracer to white with a black tracer for the normal game operation pair.
Quoted from bingopodcast:Just like that!
Terrific! I’ll check out the schematics! Thanks!
Either switch positions or dirt. Probably just a little dirt or slight adjustment needed on that one switch. Examine carefully.
Quoted from bingopodcast:Either switch positions or dirt. Probably just a little dirt or slight adjustment needed on that one switch. Examine carefully.
Gotcha. Any chance this switch would cause the tilt light not to light up?
Yes - the same switch single pole double throw either illuminates the tilt light or the backbox lights.
Quoted from bingopodcast:Yes - the same switch single pole double throw either illuminates the tilt light or the backbox lights.
Ohh ok. I really appreciate the help but I’ve been working on her for hours with no luck. I may call a repair tech who is better with EMs than I am haha. Thanks
Not a problem, sorry I didn't explain it well enough - with the game unplugged, you can examine that relay more easily. You can manually trip the relay (with a pencil or wooden dowel). Observe the switches in the tilt relay. Make sure the ones that were made break, and those that were broken, make. Lift the little brass platform with a finger and it will click in place.
Observe the switches again.
If everything looks good, clean the switch. You can use many different things to clean the switches. A piece of sandpaper cut into strips, the flextone files Steve Young sells, a regular file, or even a business card drawn between the switch leaves.
Check adjustment again. And make sure the switch stacks are screwed down nicely. If that doesn't fix it, look for broken wires on the back of the relay.
You'll have it fixed in no time.
Quoted from bingopodcast:Not a problem, sorry I didn't explain it well enough - with the game unplugged, you can examine that relay more easily. You can manually trip the relay (with a pencil or wooden dowel). Observe the switches in the tilt relay. Make sure the ones that were made break, and those that were broken, make. Lift the little brass platform with a finger and it will click in place.
I’ll definitely try that! I’ll keep you updated, thanks
Still no luck! I’ve cleaned the switch and everything. Switch appears ok? Does anyone have a schematic of what the relay should look like?
Wouldn't hurt - otherwise you have a broken wire coming off of that SPDT switch or between the switch and the jones plug. You can test for continuity using a multimeter. Try wiggling the wires a bit as well - sometimes there are cold solder joints and the solder will pop off of the switch. If that is marginal, you would get similar behavior.
Quoted from bingopodcast:Wouldn't hurt - otherwise you have a broken wire coming off of that SPDT switch or between the switch and the jones plug. You can test for continuity using a multimeter. Try wiggling the wires a bit as well - sometimes there are cold solder joints and the solder will pop off of the switch. If that is marginal, you would get similar behavior.
Gotcha, thanks. So the switch you are referring to would be any of the tilt switches?
Quoted from bingopodcast:The switch in question is a SPDT switch - the NC side is when the relay is not tripped. The NO side is activated when the game is tilted.
I believe it will be the only single pole double throw switch in that tilt relay. Note that single pole double throw means that there is a long switch leaf that 'travels' between two sides. In one position of the relay plate, it will be making on one side (not tilted). When the relay is tripped, it will open on that side and make on the other side (tilted).
That's the only thing that controls the lamps in the game, aside from the fuse.
Now, the complicated bit is that it does run through a plug or two. But assuming you don't have a broken wire in the game, it must be in one of those places. Take a close look at the whole path, and I would encourage you to look at the schematic - it shows the switch I'm talking about on the left-hand side, and you can match wire colors and so forth. You've got this.
Here are things we know:
1) 6V is getting to the backbox.
2) 6V is not getting to the playfield
3) Bulbs are good (you tested those earlier in the thread).
Right right, the only strange thing is that the game plays perfectly normal. Considering this, could we still be looking at a tilt problem?
Quoted from bingopodcast:Yes - that relay has more than one switch. Only one controls the lamps.
Alright great! When I depress the switch, the tilt activates normally but still doesn’t light the backbox
Quoted from Pinball-DOOD:Alright great! When I depress the switch, the tilt activates normally but still doesn’t light the backbox
If there's a problem with the switch on the tilt relay, wouldn't all the game's GI lamps be unlit?
Quoted from jrpinball:If there's a problem with the switch on the tilt relay, wouldn't all the game's GI lamps be unlit?
Good point!
The backbox card lamps are in the same circuit as the playfield lamps. All run through the tilt switch. So, you're left with a broken/disconnected wire somewhere. I'm guessing that it is on the playfield. Black & White wire is common - see if you can find that wire (it's connected to one side of each socket) and use your meter's continuity beep option to see if you can tone from backbox to playfield socket. Then do the same for hot (the other side). Choose a socket like the title of the game and a socket on the playfield like the arch lights. GI.
Quoted from bingopodcast:Good point!
Alright! Thanks, dudes! Getting closer
I’ve exhausted everything! No broken wires anywhere
Someone swapped the fuse positions and confused everything. The fuse holders are placed in the wrong order
This page was printed from https://pinside.com/pinball/forum/topic/queen-of-diamonds-back-box-lighting-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
