Hello,
I went to a clients home and he has a bad relay for the beacon. I forgot to look at the specs. I'm assuming 24 volts? As it has 34 vdc going in with a 100 ohm resistor in line per schematics. Thanks in advance! If you could check . JR
Hello,
Williams # 5580-10883-00 is what's listed in the manual for the beacon light. Marco crosses it to # 5580-0541-00.
http://www.marcospecialties.com/pinball-parts/5580-0541-00
It also crosses to MCM Electronics # 26-534B
http://www.mcmelectronics.com/product/26-534B
Parts Express has it too.
These are common automotive Bosch/Tyco 20 or 30 amp relays so you may be able to scare one up at your local auto parts store.
Here's what's electrically inside the relay and it's connections:
http://www.texasindustrialelectric.com/relays_0332209150.asp
Thanks for the help. So it's a 12 volt relay ? just wanted to make sure because the old one has 34 vdc going to it through a resistor. Thanks jr
Can also find the weatherproof versions here:
https://www.greatplainselectronics.com/proddetail.asp?prod=CB1-WM-12V
Don't exactly need weatherproof but the price is right.
This page was printed from https://pinside.com/pinball/forum/topic/q-wondering-relay-specs-for-high-speed-beacon and we tried optimising it for printing. Some page elements may have been deliberately hidden.
