I had a call on a Bally Pool Sharks with a bad relay a/c select relay as the auxilary driver bd had a hole burnt in it and was repaired. Flashers were inoperative but the board was so hacked that I decided to replace it with a clean board with new relay. 1 month later customer calls and ball wont eject. Relay is toast internally as pictured. I was puzzled as i figured a fuse would blow before the relay arced itself to death.
Looking at the back and schematic it seems the 50 volts goes to feed the flashers via the relay and is not fused.
Anyone have any ideas? I plan to put in a new relay and want to fix the issue.
Thanks in advance JR
