This is driving me nuts!
I took the idol off, the yellow plastic and the motor below to clean them all.
Now when I put the idol back onand tighten the set screw to the flat part of the motor post, the idol seems to sit too low - so balls can't enter it (see photo). If I lift the idol up to make room for the ball, it will no longer tighten onto the motor post as the set screw is now too high.
I thought maybe the motor post is sitting too low, but it looks the same as a 'before photo' I took - about half an inch above the yellow plastic - and I don't think there's any way to make it higher anyway as the motor below the playfield is screwed in properly.
I'm sure there's an obvious solution but I've been working on this for an hour and it's killing me!
Please help somebody!!
