(Topic ID: 265740)
purpose of capacitor in Strange World
By paulace
53 days ago
  • 23 posts
  • 8 Pinsiders participating
  • Latest reply 51 days ago by paulace
There have been 7 images uploaded to this topic. (View topic image gallery).
#1 53 days ago
One more question (for now) about this Strange World schematic I've been looking at. Does anyone know what the purpose of the circled capacitor is? It's rated for 100V - is there some sort of kickback voltage occuring here?
Since I'm obviously not smart enough to figure it out myself, I await enlightenment....
Thanks in advance!
#2 53 days ago
According to pinrepair.com, possibly because of sparking caused by EMF.
#3 53 days ago
Probably for timing/pulse stretching.
#4 52 days ago
Thanks slochar - so where would those voltages be coming from - the score reel coils?
Thanks KenLayton - can you tell what pulse needs to be stretched or timed differently? I just don't see many caps in EM's...when I do, it's usually something to do with a timing circuit, but I don't see where that would apply there. Just trying to learn.
#5 52 days ago
The labels on that schematic look unusual. The fonts don’t match anything I’ve seen on another Gottlieb.
#6 52 days ago
Quoted from leckmeck:
Wonder if maybe someone updated it if it had incorrect info or something like that?
#7 52 days ago
... and a feature lamp on the 24V side? Strange World is living up to its name!
#8 52 days ago
leckmeck - That's a re-drawn schematic. Just for fun, I re-draw Gottlieb schematics in Photoshop - well, partly because I enjoy it, partly because it's really nice to have a 2-foot wide schematic laminated so I can draw on it and trace circuits and just erase when I'm done...plus they look cool hanging on the wall. I just chose a font I thought was easy to read....I keep them consistent within my own re-draws. The information on it is correct, though - straight from a legit schematic.
DaMoib - Yeah, you don't see many lamps on the 24V side for sure...but this one was designed by John Osborne, not Ed Krynski. I suppose he had some different ideas....ever seen the inside of Haunted House?
Here's the section of the original schematic....unless I make a mistake, the information is correct.
#9 52 days ago
So the only thing I see there that looks like it would be sensitive to a voltage spike is the light bulb....is the purpose of the capacitor just to protect the bulb from blowing if a voltage spike shows up?
#10 52 days ago
Resistors were often used to prevent arcing across contact points due to EMF. (EMF describes how an inductor or solenoid tends to continue pushing current through a circuit even though a switch on that circuit has opened. If enough current is pushed through, the voltage on the open contact can rise to the level where it will arc across the air gap to the other contact.) Here is an example from Bowling Queen:
Resistors seemed to appear on 0-9 units (or 00-90 units on later games) for reasons that aren't clear to me. It implies that the contacts on these units were more susceptible to arcing than other contacts in the game. On Strange World and other later games these were often AS relays or mini steppers which have smaller contacts which may be more easily damaged by arcing. But even earlier games with regular steppers and snow shoe wipers often used resistors.
In this case the capacitor is unexpected. It's wired in parallel with the Add Replay Unit solenoid which is larger and would draw more current than a relay coil so it makes sense that it's there to suppress arcing. I don't understand though why a capacitor was used instead of a resistor if arc suppression is the reason it's there.
/Mark
#11 52 days ago
Thanks Mark,
Was it just there to protect the bulb from higher than normal voltage transients coming from somewhere down the line? I suppose a capacitor would short a transient more effectively than a resistor? (He asked uncertainly...) I mean, I know caps are typically used to allow AC to pass while blocking DC, but there's nothing but AC in this machine, so it's gotta be passing an unusual AC event, right?
#12 52 days ago
With the age of the capacitor should it be replaced?
#13 52 days ago
Possibly - it's 42 year old now. How will I know if it's not working if I don't know what it does? *laugh*
#14 52 days ago
Quoted from paulace:
That's exactly what I'm wondering.
#15 51 days ago
How a capacitor behaves depends on the topology of the circuit. A capacitor in series would block DC and allow AC to pass (like a coupling capacitor in audio equipment) but a capacitor in parallel wouldn't affect DC and would tend to smooth out the AC. Since the capacitor is essentially in parallel with the solenioid I think it's there to suppress induced voltage spikes. Whether the intended beneficiary is the AS relay contacts or the bulb I don't know.
#16 51 days ago
Thanks Mark - maybe when I get my hands on the machine, I'll use the experimental method - unhook the capacitor and see what blows up. (just kidding)
#17 51 days ago
The schematic does NOT show a polarity on that capacitor. Is it an electrolytic type?
#18 51 days ago
I don't know, Ken - I don't have the machine in front of me. Might have it to look at on Friday....I'll see then.
#19 51 days ago
20200405_203515 (resized).jpg20200405_203637 (resized).jpg20200405_203651 (resized).jpg
#20 51 days ago
Ah.... it's a non-polarized (a.k.a. Bi-polar) electrolytic. That means it's being used with AC power.
Somebody should add the designation "B.P." or "Non-polar" to the schematic next to that capacitor.
#21 51 days ago
Quoted from KenLayton:
So with the age of it should it be replaced?
#22 51 days ago
It looks to be in good physical shape. A capacitor "value" reading meter could be used to test it. It's probably ok.
#23 51 days ago
There...now people in the future will know for sure!
Pinball Wheezer
Gameroom Mods
PinWoofer
$ 69.99
$ 29.50
Playfield - Plastics
$ 224.99
$ 89.99
$ 49.00
Bent Mods
$ 18.99
Various Novelties
GC Pinball
$ 5,899.00
Operation Pinball
$ 249.00
$ 84.95
$ 175.00
Professor Pinball
$ 150.00
Republic Of Pinball
$ 5,899.00
Operation Pinball
$ 54.99
$ 99.00
$ 18.00
The MOD Couple
Various Novelties
GC Pinball
