how easy/hard is it to pull a pinball 2000 monitor? how does it come out ?
thanks
I’m guessing you got it out by now - if not, it’s pretty easy! You need to discharge the flyback as with any crt before messing with it, then it’s really just a few plugs get unplugged, remove the computer up top to give yourself room, and the 4 bolts you see from the back get removed to release the crt. Just pay attention to where stuff was plugged in or take pics before and you will be fine. Also - make sure you check that a green ground wire is disconnected with a wing-nut at the bottom left corner. If you haven’t discharged a crt before - YouTube it and be careful - it can zap you or worse if you don’t.
This page was printed from https://pinside.com/pinball/forum/topic/pulling-a-pinball-2000-monitor and we tried optimising it for printing. Some page elements may have been deliberately hidden.
