I'm looking into changing the LM323K regulator due to heat on my WCS94 driver board. Has anyone installed the PSU5 replacement in a WPC-89 board? How did work?
https://www.ezsbc.com/index.php/featured-products-list-home-page/psu5.html#.XfLSrvyIZzm
I wouldn’t.
1. The heat isn’t an issue. That’s what the big heat sink is for.
2. The regulator is working. Why mess with it?
3. The ez part causes the sound board to emit a machine gun sound on power down. It’s annoying.
4. The LM323K isn’t a significant reason for resets. Connectors cause far more resets than the LM323K.
Chris Hibler - CARGPB #31
Http://chrishiblerpinball.com/contact
http://www.PinWiki.com/ - The new place for pinball repair info
Quoted from ChrisHibler:I wouldn’t.
1. Heat does cause damage to the boards over time and dry solder joints. It also puts more load on the 12v power supply including the connectors and board components in that chain. The waste heat is created as part of the original linear regulator's design to lower the output voltage to 5v.
2. These regulators do cause intermittent issues. For example, I re-capped my power supply in Police Force and am still only getting 4.95v out of it. This is with no 5v loads connected. As a result the game often does not boot.
3. Simply a personal preference vs. how good the game functions after upgrading the regulator.
4. It is often not, but with these parts often times being over 30 years old, that statistic is changing.
Quoted from Crash:2. These regulators do cause intermittent issues. For example, I re-capped my power supply in Police Force and am still only getting 4.95v out of it. This is with no 5v loads connected. As a result the game often does not boot.
That minor voltage variation isn’t enough to cause resets. People always talk about low voltage but there are other factors. I have WPC boards that output 4.85VDC and they run fine in my TZ.
If it ain't broke don't fix it.
If you're operating the game MAYBE address heat issues, but home use even with weekend parties? Nah.
If you replace your low voltage regulator you also risk pulling traces/through holes and causing damage to your board unless you have the proper tools and technique. Its not an "easy" swap, FYI
I'm having an issue with mine in my Police Force. It doesn't seem to be switching/regulating properly and outputs way too high. Fortunately I decided to test this before connecting any of the boards. Before I swapped this the game booted once, but did not boot subsequent times. I wanted to try this and here is what I'm seeing. I have it installed with alligator leads connected to a 555 lamp.
I'm getting this on the 5v test point:
So I decided to check the input vs. output test points on the PSU5.
Input:
Output:
I took another one of these and fed it 13.5v from my bench power supply. I hooked up the lamp and it's now getting 5v which is normal. Do I need to check something else on the power supply board, such as the regulator IC? I'm getting the same output regardlesss of if I have the lamp connected or not. Maybe I have a bad one.
Nevermind, this is evidently a 2N6057 power transistor and not an LM323K regulator. My transistor got so hot the ink vaporized off and I couldn't tell what it was. That and some evidently incorrect advice I came across caused me to think it was a cross-compatible LM323K, lol. In this case I'll replace the 30 year old MC1723CP regulator IC as all the caps have been swapped.
If you measure the output of the LM723 pins 4 and 5 and the measurement is equal then the regulator is fine.
This page was printed from https://pinside.com/pinball/forum/topic/psu5-lm323k-replacement and we tried optimising it for printing. Some page elements may have been deliberately hidden.
