(Topic ID: 326556)
Prospector..turn off extra ball ?? (Solved)
By lowbeau67
1 year ago
#1 1 year ago
Taking my prospector to pincinnatti and need to turn off extra ball feature.
Looked at it today and was reading manual and looking in backbox and can't quite figure it out.
Erik is putting it in tourney and I need to get it turned off.
Thx for any help
#2 1 year ago
Since it’s an add a ball machine, I don’t believe there is a simple jones plug to turn it off. You could just de-solder the hot wire to the extra ball relay.
#3 1 year ago
Being that the game is similar to Yukon, you could look in the backbox and see if you can see this wheel adjustment. Just set it to replay.
B463C7B4-79F6-47A3-BF9F-69E815CA1BB8 (resized).pngB463C7B4-79F6-47A3-BF9F-69E815CA1BB8 (resized).png
#4 1 year ago
Quoted from Mikala:
It's not an add a ball machine, but your solution is correct. Just disconnect the extra ball relay coil, and then you can't get extra balls!
For bonus points, also take out the lamp for the 'extra ball when lit' arrow on the right kicker
#5 1 year ago
You could just block the normally closed switch in the red box on the Extra Ball relay to keep it from firing.
Prospector Extra Ball relay (resized).jpgProspector Extra Ball relay (resized).jpg
The game does have a credit/extra ball adjustment but that does not disable the extra ball awarded by the Canyon switch after relays 1-4 have been activated.
/Mark
#6 1 year ago
Quoted from MarkG:
/Mark
So that switch has a jumper and a yellow wire and is n.c.?
Looking at the bank relays not sure what switch it is.
PXL_20221128_154419035 (resized).jpgPXL_20221128_154419035 (resized).jpgPXL_20221128_154720830 (resized).jpgPXL_20221128_154720830 (resized).jpgPXL_20221128_154727609 (resized).jpgPXL_20221128_154727609 (resized).jpgPXL_20221128_154742473.MP (resized).jpgPXL_20221128_154742473.MP (resized).jpg
#7 1 year ago
That’s what I do. Put paper or cardboard to block the switch closure, remove playfield lamps.
#8 1 year ago
Quoted from lowbeau67:
Yellow-black wire.
It's the last switch in your photos, switch 1D, top of the stack, all the way to the left, mounted above the Extra Ball relay in the trip relay bank.
#9 1 year ago
Found it.
So I want to keep it n.c.?
So wrap some tape around it I assume.
#10 1 year ago
Found it.
Or clip an alligator clip to it.
#11 1 year ago
Quoted from Mikala:
Yep. That's what I did.
#12 1 year ago
Ok I've got a tiny ziptie and alligator clip. Will report back
#13 1 year ago
Did a ziptie and then the clip as shown.
Still awarding extra balls.
#14 1 year ago
No, you want to force it open to prevent the relay from firing. You need to block it with paper or something similar as chuckwurt and I mentioned earlier.
#15 1 year ago
Quoted from MarkG:
Oh ok. Gotcha
#16 1 year ago
Prospector is ready for pincinnatti!!
Thx for all the help.
#17 1 year ago
Quoted from zacaj:
I have played the game before and didn’t think it was an add-a-ball, but IPDB had it listed as an add-a-ball, so that confused me.
#18 1 year ago
You could have also slipped a cut McDonalds straw over the leaf switch. I do this during testing.
#19 1 year ago
You can also simply adjust the switch so it doesn’t close, then readjust back when you want extra ball awarded again.
The Pinball Scientist
This page was printed from https://pinside.com/pinball/forum/topic/prospectorturn-off-extra-ball- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
