Quoted from MarkG:Start with a good cleaning. Sanding and lubing are overkill in many cases.
Sweet. That did it for all but the 60,000 light. I'm assuming I can troubleshoot that with a jumper wire from the bakelite plate to the bulb socket?
I'm see a few other issues and was thinking you might be able to help.
A lot of them surround coils. You don't happen to have a coil list do you? I don't want to order the manual, find out the coils are wrong and have to make another order and pay double shipping. I think I'm going to need some other parts too as I work through these issues.
The left flipper is significantly weaker than the right. They have different coils numbers. The center kickout is also really weak. I took a few winds off the spring on the kickout mechanism and it's better, but still weak.
I also noticed that the playfield features don't ever change, which I'm assuming is the match unit? It just so happens that the match is always 000, so it's probably something with that, but without a schematic, I wouldn't be able to tell.
