Greetings,
I'm new to the pinball hobby, by acquiring a Williams Space Shuttle. I'm pretty handy and I figured for $550, the machine is solid enough and I can render the TLC it needs. Of course, it needs a bit of cleaning, some switches fixed, and a coil or two - typical stuff. But it passes all diags as near I can tell, and I fixed a few other things broken at sale, so I'm already way ahead of where it was, and I like fixing things.
While cleaning the playfield I noticed the foam behind the bank targets is worn... to the point where in most cases it's missing. It looks similar to the gray 1/4" weatherstripping you can get anywhere, but of course on the machine it is black, and seems denser. Is there a proper type than can be had easily and affordably? While my gray weatherstripping foam work OK or deteriorate too quickly?
While at it, seems one of them was replaced as its target is a simple red blank and its foam is different. It almost looks new. Would anyone be willing to trade, or have a spare Williams concentric white ring switch to part with?
Thank you...!
