(Topic ID: 116874)
Project Yabba Dabba Doo - adventures of first time operating!
By johnwartjr
9 years ago
  • 126 posts
  • 41 Pinsiders participating
  • Latest reply 8 years ago by RampShot11
  • Topic is favorited by 26 Pinsiders
There are 126 posts in this topic. You are on page 3 of 3.
#101 9 years ago
Installed new leg bolt plates and Stern cabinet protectors today.
This cabinet is heavily worn and well loved.
But, these will keep it from getting worse. I am considering painting the cabinet where the artwork is wrinkled off. With the pattern on this cabinet, flat black won't look that bad.
#102 9 years ago
I wish you were routing this closer to me, I would play the hell out of it.
#103 9 years ago
So, a little progress tonight, starting to reinstall stuff...
Front of the cab, coming together! I need to order the correct gold leg bolts, I thought I had a set, and didn't!
Woofer in place. This little Dayton Audio woofer is a great fit on DCS games.
https://www.parts-express.com/dayton-audio-dc160s-4-6-1-2-classic-shielded-woofer-4-ohm--295-308
#104 9 years ago
Another enhancement, the Mantis Amusements ball trough, special thanks to my buddy RD!
I'm sure we are all used to the stock troughs, that get divots in them, and have to be filed out ever so often...
Kerry made a neat-o trough that has hardened rods in it that the ball rolls along that should pretty much never wear out - and if they do, flip them over and wear the other side out!
And, it has its own answer to the captive ball stop built in.. slide the lever up, the balls can't fall out of the trough!
#105 9 years ago
I have ALOT of nos plastics for this......... From the looks of it, this is coming along nicely
Great project
#106 9 years ago
trough is killer!
#107 9 years ago
Quoted from Pinwow:
Great project
I might have some trades, if you're interested in parting with some of them
#108 9 years ago
Yeah I might, I'm actually at a show right now so I will see exactly what I have when I get back
Thx
#109 9 years ago
Quoted from johnwartjr:
That's sweet!
#110 9 years ago
Wow! This is a project of love! You do an amazing job on cleaning up the parts! I'm even more impressed you can figure out where all those screws go! My luck, I would have a lot left over!
Thanks for taking the time and snapping all the pics of your progress! Very fun to watch!
Joe
#111 9 years ago
Quoted from Pinwow:
Great project
Pinwow - I am nearing the end of a Flintstones restore as well. There were a few plastics that I was considering replacing due to some slight yellowing. Do yo have a list, pics and prices you were looking to get for these?
#112 9 years ago
Old ratty stained up lamp insert. No amount of cleaning would remove all the bulb burn marks.
Some white krylon does the trick. It took about 6 faint coats to cover everything up.
Excuse the mud on the back porch, my 7 year old digs beside it sometimes, and I need to get the garden hose out and spray the patio down - but it has been raining on and off all week, so I don't want to soak the back yard anymore right now.
I'm considering doing this on mine as well. I really don't see myself removing the wiring. Is there another method to covering the bulb sockets from getting painted?
#113 9 years ago
If removing the wiring isn't for you, you can put some old bulbs in the sockets and they will keep the contacts clean while you respray.
Once you've removed all the hardware (you don't want to paint that, right?), the harness isn't much more work to remove.
#114 9 years ago
Okay...thanks for the advice johnwartjr. I'm thinking of cotton balls stuffed over top of the sockets but haven't tried it yet...seems like it would work. Haven't taken the wiring apart before on the backboard and don't have the IPS tool to push wires back so I'm a little leery. It's not horrible but definitely has a bit of a yellowy tinge. Hmmmmm....
Spent sooo many hours touching up a spot on the playfield that I missed before it was cleared....grrrr.
Finally got it but was really hard to match the yellow...not great but better than it was. As usual, the clear made darkened the acrylic. Luckily it's in the outlane near the bottom and only the size of a pea. Not sure that I have the energy to tackle the backboard today.
#115 9 years ago
I would strongly suggest buying an LED OCD board for this game. Even though you won't be playing it regularly since it will not be at your home, it's worth every penny of $150. There's a good chance the unsmoothed bright flickering LEDs would disorient and turn off at least a few of your customers.
#116 9 years ago
John,
I can't believe it has taken me this long to stumble onto this post.
WOW...you're really doing a serious number on that machine.
(and I thought I got pretty deep into my restores)
If you need a hand w/ anything, you know how to reach me.
#117 9 years ago
No need to remove the wiring from the backbox sockets.
Find a socket about the size of the hole in the backbox insert, place it against the sockets, and give the sockets a few gentile taps with a rubber mallet. They will come out with gentile persuasion. If you don't wail on it, there will be no need to push any wires back into the sockets - they won't come out.
#118 9 years ago
Okay...you've talked me into it. I know it's the right way to do it but I just finished putting the playfield back together and getting a little anxious to finish up in short order. I'll let you know how it went.
#119 9 years ago
Ramps arrived from Oz!
#120 9 years ago
Sharp.
Great thread John. Keep posting!
#121 9 years ago
Well, I went ahead and cleaned the board ground plane and installed the boards tonight - before I realized I haven't braided the head and cabinet out. Oops. Oh well, they will be safe for a few days until I get around to braiding the cabinet
Found these in a folder today, came with my 'adult' translite.. really debating how wise it would be putting a game on location with an overlay. Makes me wonder how likely it is to stay 'down' without lifting. The pink one isn't for me, I don't expect I'll be using it
#122 9 years ago
Honestly I hate the cartoon decal. Pin is fine as is.
#123 9 years ago
Keep it stock, nobody wants to see that mess on a beautiful location game.
1 month later
#124 8 years ago
How's the pin coming along?
1 month later
#125 8 years ago
Since I'm lacking on updates...
I am having a tough time dedicating the time to getting this ready, so in the meantime, I decided to put another game in the location.
I'm preparing my white water to go on location. This is a 100% working, great playing game that is in my restoration queue - but I'm putting a Color DMD in it this week. Expect to have it on site in about a week. Right now, I installed the Cliffy VUK drop protector, as the ball is getting hung up on the mini playfield occasionally where it ejects the VUK, and am putting in the Mantis lock target protectors, repairing a couple stripped post holes, and just giving the game a thorough once over.
Once the Flintstones is ready, I'll bring White Water home. I have a new set of playfields for it to install at some point. Maybe the coin drop will make a dent in the set of ramps I need to buy for the restoration.
I'm also swapping in a solid lower cabinet from a parted out machine. The one on the game right now is really rough!
#126 8 years ago
I played Flintstone's at Pinfest this year, I loved it!!! Such a great game. I don't think the owner was selling it because I might have made an offer. Can't wait to see yours once it's done.
$ 18.95
$ 3.00
Tools
Nezzy's Pinball Prints
$ 22.50
bdash's bits
$ 6.95
$ 37.50
$ 329.99
KAHR.US Circuits
$ 12.50
$ 14.95
PinSound
$ 17.95
$ 7.50
$ 9.95
$ 72.95
$ 5.00
This page was printed from https://pinside.com/pinball/forum/topic/project-yabba-dabba-doo-adventures-of-first-time-operating/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
