So, I needed to get the speaker panel configured for the 5-1/4 speakers.
One side is already done - easy peasy.
So, how to get the 5-1/4 on the other side?
Well, Tony's Guide is a good start..
http://dziedzic.us/wpc_speaker_replacement.html
I have done probably 10 games using his guide and have always been happy. I believe it's best on DCS or later games - the earlier pre DCS games just don't have the power to drive better speakers, unless you want to add an amp, and I have never found one I wanted to go that far with.
So, I started with this..
My Dad is a woodworker, so I asked him to make me a jig after looking at Tony's site. Figured it would be the easiest way to get the hole in the right place.
A router is probably an even better choice, but I don't have a router, and I do have a drill press. I'm kinda thinking I might like to have a router for a number of reasons, but that's another discussion
So, stick the speaker panel in the jig, put the circle cutter in the drill press.. couple clamps for good measure
Drill a little
Drill a little more..
Now, the speaker hole is perfectly sized, in the right spot!
I forgot to take pictures of the process of using a speed square to mark out the new holes, and then drilling new holes, but Tony's site covers that pretty well.
Then, I use a forstner bit to cut the t-nut recess with the drill press
Don't drill all the way through the panel. Just drill enough so the flange of the t-nut will fit below the speaker grill
Ready to re-attach t-nuts!
Now, I've had a few of these made by a buddy on a CNC mill.. unfortunately, he no longer has access to the CNC. His work looked nicer than mine. His machine was a million bucks. My drill press is a hand-me-down from my Dad, with a jig made out of scrap lumber, a $20 circle cutter, and a $10 forstner drill bit set from Harbor Freight.
Once the t-nuts are installed, and the panel is resprayed.. my modified speaker panel looks pretty much as good to his from the players perspective, and once the speaker is installed on the back side, you'll never notice if a screw is off by a centimeter or something
