A slow day at work allowed for the beginnings of insert installation.
A two-part epoxy was applied to the wood opening as well as the rim of the insert prior to tapping each one in place.
I did decide to deviate from the original color choices in some areas. The 2X is still yellow, 3X is now blue (vs. green), and 4X is now red (vs. white). All specials are now amber/orange. All colors are now translucent where as before there was a mix of opaque and translucent. The large one inch inserts are still opaque white as that is what looks best behind the illuminated predators.
A close up of some colors.
Red, Yellow, and Blue compliment the rest of the playfield nicely. Especially when compared to the green -- which I don't think is utilized anywhere in the artwork. I also replaced the A-B-C rollover inserts at the top (originally green) with translucent yellow.
I did not replace the yellow arrow inserts because I could not find suitable replacements from all the usual sources. All out of stock.
As is usually the case with me, I missed one insert on my order. I'm sure you can see which one. Sadly that means no sanding or hardtop installation over the holiday weekend. . . but that is ok because there is still plenty more to do.
Speaking of plenty more to do, I stopped over my brother's house after work to look over his Flash Gordon. He is blowing a fuse on his power supply board and I think he has a compromised bridge rectifier. Discussions quickly escalated from replacing the board to an overall refurbish of his game. I told him I'd have to think about it.
I was not aware that picture was being taken.
Merry Christmas Pinside!!!
