Plastic Protectors.
As I had mentioned earlier I like the color accents a set of these can provide (if using something other than clear), but not every game has protectors available from various suppliers. I still have a connection or two that may work out in terms of getting some laser cut, but for Seawitch I decided to take matters into my own hands.
For starters I ordered some Acrylic Plexi in Neon Blue. I suppose I could have gone with yellow too, but at least I know the blue should blend with all the other blues on the playfield. The blue is also more subtle due to reflected light wavelengths and what not (or so I've read ).
I traced the original plastics onto the stock sheet.
Then I used a table jig saw to cut the shapes -- as best I could. Sometimes leaving a little extra around the edges/curves was to my advantage.
A belt sander was used to clean up the edges and smooth out the curves.
At this stage I have the shapes made and a drill made easy work of making the mounting holes.
Done? Not quite. A close look at the edges of the plastics reveals a less than pleasant cosmetic effect. If a laser had cut these the edge would be polished and shiny.
I tried several techniques to smooth the edges. Ultimately I gave them a sanding down with 80 then 220 grit sandpaper. Then, to duplicate the heat/meltiness that would have resulted from the laser I glazed over the edges with a propane torch.
I put the plastic in the vise for the picture, normally I held them by hand. Its just hard to take a picture, hold a plastic, and wield fire all at the same time.
Top plastic is sanded and flamed. Bottom plastic is rough cut. Getting closer to a desired result, just not quite there yet.
Success came when I decided to run the edges of the plastics along the compounding wheel.
Much smoother. . . with a hint of sparkle!
Holding the protector under a plastic in the light gives an idea of what type of effect we may see once they are installed. Still the hint of a saw mark or two (or more), but not bad.
The complete set ready for installation.
Was it worth the couple hours invested? I suppose we will see once they are installed and the game is together. I will say that I usually set my standards high and at the end was rather pleased for how things turned out. At least I'm pleased with how they look sitting on the kitchen table anyway.
