Last weekend I got some job done on the project, last side of the cabinet was painted.
Here are some step by step photos, it’s a little bit of repeat from previous post but I hope someone will find it interesting.
Starting with the stencil for the green pattern. Here is the stencil with the transfer film still on. First make sure the alignment is right before sticking it in place and then carefully remove the transfer film.
Masking everything thats not going to be painted.
Layers and layers of green paint applied with air brush.
The green layer finished and set to dry for 24 hours.
Then using the small square boxes to align the last stencil.
Again masking everything that is not going to be painted and then starting with the yellow paint.
Once the yellow is done its time to start peeling of the stencil.
And here’s the result.
Once the paint was completely dried it was time for some fun, putting temporary legs on and to start fitting the lower playfield with the main playfield.
I got a parcel from USA on Monday, it was the last metal parts that Rob W C had sent me so hopefully I get some time this weekend to polish them and install them on the playfileds.
