LEDWholesalers.com has two products that can replace the flourescent tube in your Stern backbox.
The Warm White tube (3100-3400K) is $24:
http://www.ledwholesalers.com/store/index.php?act=viewProd&productId=966
The Neutral White tube (4100-4500K) is $22:
http://www.ledwholesalers.com/store/index.php?act=viewProd&productId=956
I'll abbreviate these as 3100K and 4100K. I ordered 2 of each to try them out on my Sterns, which set me back about $100. Here's a quick summary of the pros and cons:
Pros:
* They turn on in about 1/2 second.
* The ballast is bypassed, so they should produce less heat.
* They use about 50% less power, and should last much longer.
* The 3100K tube is warmer and about 10% dimmer than the flourescent tube. This works well for translites with skin tones, such as LOTR.
* The 4100K tube is an almost perfect match for color and brightness
Cons:
* Light dispersion is not quite as good as flourescent.
* Wiring must be modified before installation.
I'll go over the installation next.
