Quoted from RonaldRayGun:- Check fuses.
- Check voltages at test points.
- What are the LEDs on the boards showing?
There is three leds...
DSC_0369 (resized).JPGQuoted from Phat_Jay:Show the ones on the mpu board please.its the board to the left.
No leds
DSC_0370 (resized).JPGCheck fuse F115. Also check the connector at J101 on the power board. Pull it off and examine it, does the connector (or the pins) look burned or discolored?
Quoted from gunstarhero:Check fuse F115. Also check the connector at J101 on the power board. Pull it off and examine it, does it look burned or discolored?
Could be something with J101. I wiggled it and something happened. It scared me
Quoted from Mark73:... It scared me
Haha! Really? Owning 9 pins, something happens and you’re scared?
Not a real Viking, are you?
Your driver board is showing it has power but mpu board does not. Something between the two has a problem. Check the power connectors linking the two and the fuses. For giggles id pull the two boards and look on the backs of them for burn marks. Ifweelinate possibilities we’ll narrow things down.
Quoted from Thor-NL:Haha! Really? Owning 9 pins, something happens and you’re scared?
I just play on them. Not so good at repairs...yet
Quoted from Mark73:Could be something with J101. I wiggled it and something happened. It scared me
No need to be scared. J101 is 5V from your power board to your MPU. If your MPU doesn’t get power it won’t boot, surprise!
If the pins are loose or the connector is burned or damaged it causes that kind of behavior. Sounds like you need to rebuild that connector.
For what its worth, your Power Driver board pictures shows LED4 out ( right in the middle of your picture), this is your +5V coming off the regulator on the Power Driver board. Nothing is going to work without that voltage.
Quoted from gunstarhero:No need to be scared. J101 is 5V from your power board to your MPU.
Not exactly...but it can effect it.
Yeah, I wouldn't mess with J101 with the power on; J101 is your AC transformer voltage coming into the Power Driver...You should be scared messing with that one.
Quoted from Pin_Guy:Not exactly...but it can effect it.
Ah, thanks for the clarification. Thanks Pin Guy!
Plus, YES, always be careful around live boards. Don't be too scared to do anything, just PLEASE be smart about it.
Quoted from Pin_Guy:Have you already verified F113 is good with your meter?
F113 was ok but not F111. I replaced it but no change.
This page was printed from https://pinside.com/pinball/forum/topic/problems-with-wcs94 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
