Quoted from Spiderwolf:I just bought a new Godzilla Premium and right off the bat the upper flipper does not work all the time. The problem comes and goes. Yesterday it seemed to be working fine and today its hit and miss. Bottom flippers work perfect. Is this just an adjustment or something easy, or do I need to get it looked at under warranty. Also, the bump bar action button lights up but nothing else. It will not launch the ball. Unless there is something different about Godzilla, most other modern sterns launch the ball. At least the ones I have. Again, simple or should I call Stern or who to do warranty repairs. I've never had a new machine that didn't fully work, so not sure of the procedures as far as getting it fixed.
Most likely a leaf switch adjustment that controls upper flipper. This will be on your lower flipper most likely. I don't own a stern but assume their flipper mechs/swtiches haven't changed too much.
Start at the 3 minute mark of this video link below. Also take a dollar bill and clean the little round contacts between the leafs. Literally pinch the dollar in between the contacts and pull it through.
As far as the launch button on top. Assuming that's how it supposed to work, take the lockdown bar off, start a game and manually trigger the switch and see if it operates like you want. If it does, adjust as described in above comment. Move the switch closer to the button or adjust the action button bottom to go further down. Maybe there's a screw you can turn out or something.
r/
Mike
