Hi,
i'm trying to repair a Gottlieb Solar Ride.
I've repaired the powersupply and i have al the good voltages.
Every day it is a step further but now i'm stuck.
I have replaced the A1-J5 cable since it was damaged by leaking battery.
I think there is still something wrong with the connections on the CPU-board itself.
I've renewed the connector A1-J6 but still problems.
After shorted capacitor C2 on CPU-board (for disabling the slamswitches) i get the following things after power up, which can be seen in following movie:
After pressing the on off button i have got the typical 5s-delay. I can already activate the flippers then ????
There are already lights activated on the playfield which shouldn't.
After pressing the creditbutton, i get a double beep and the displays freeze, i can still use the flippers.
Does anyone know what the problem(s) can be ?
Thanks by forehand
